vagner
Comando ou Script para ativar campo "Trial"
Fri Oct 27, 2023 8:16 pm
Hello friends of the community, I'm a beginner here and I would like to ask for some help!
I would like to create or see what command I could execute to activate and deactivate the "Trial" field in:
IP - Hotspot - Server Profiles - (server name) - login tab - "TRIAL"
How can I create a command for me to execute via terminal or script to ACTIVATE and DISABLE this option?
rextended
Re: Comando ou Script para ativar campo "Trial"
Sat Oct 28, 2023 1:56 pm
Is not one "flag" on or off.
Is one array where trial is present or not...
If you're not familiar with scripting, better leave it alone.
radnom code
foreach item on array,
    copy the value in new array except if is "trial" and must removed,
        if trial must be added,
            if trial is not already present, add trial at the end
vagner
Mon Oct 30, 2023 1:04 pm
Hello my friends!
It's resolved!!
I was able to create the command to "Enable" and "Disable" = IP HOTSPOT PROFILE = TRIAL.
If anyone needs it, just run and test:
COMMAND TO ACTIVATE:
ip hotspot profile set [find name=test] login-by=http-chap,mac-cookie,trial
COMMAND TO DISABLE:
THANKSSS!!!! ;)
Users browsing this forum: No registered users and 8 guests
