janosikl
RB450Gx4 DC in 24V but PoE out only 9V
Wed Nov 01, 2023 2:01 pm
I have RB450Gx4 what is powered by 24V DC adapter, and try to attach hAP AC lite over PoE but it didn't work. Then I measured the voltage on RB450Gx4 PoE out (Eth5) with a multimeter and only 9V. Why? What could be the problem? (rOS v7.11)
FYI: I measured 24V on hAP AC lite PoE out interface when I powered in a 24V DC adapter.
Regards
mkx
Re: RB450Gx4 DC in 24V but PoE out only 9V
Wed Nov 01, 2023 4:34 pm
MT devices typically don't do voltage conversions for PoE. If you measured much lower PoE out voltage than supply voltage (0.1V is acceptable, 15V is not), then there's a hardware damage in your device.
janosikl
Sun Nov 05, 2023 3:28 pm
I tested my hAP AC lite PoE out voltage again, and I measured same 9,6V when the port PoE settings is off or auto on (not attached PoE device) or the device is shutdowned. When I set this port forced on, then measured 24V.
So I'm thinking it possible it's just a bug in rOS 7.11 or a bug in RB450Gx4 firmware.
Reinis
Mon Nov 06, 2023 9:50 am
Both mentioned devices have passive poe-out ports: they perform resistance check and if it's in specific range, the port is turned on (https://help.mikrotik.com/docs/display/ ... tstandards) The voltage you measure is "detection" voltage in order for the PSE to measure resistance, this is done on any PSE.
normis
Mon Nov 06, 2023 10:50 am
To add to Reinis post - it means the port is not yet on. It will be turned on, when a device is connected.
janosikl
Mon Nov 06, 2023 1:06 pm
Thanks, but the port won't turn it on if I connect a device (hAP AC lite) to it, no matter how it's configured in the rOS 7.11 (auto on or forced on). I tried it more PSU like 24V 0,8A, 24V 1,5A, 12V 1,5A.
Any other ideas?
Reinis
Re: RB450Gx4 DC in 24V but PoE out only 9V  [SOLVED]
Thu Nov 09, 2023 11:31 am
Any other ideas?
If setting poe-out=forced-on on PSE (RB450Gx4) does not turn voltage on B pairs above detection voltage (9V), then most likely something has burnt/degraded.
Note: forced-on mode should always enable voltage on port, no matter what is at the other end, ofc, not if port is shorted.
janosikl
Fri Dec 01, 2023 7:43 pm
Then it seems to be really harver problem.
Users browsing this forum: No registered users and 3 guests
