GREGT
CCR2116-12G-4S+ worse performance than CCR2004-1G-12S+2XS?
Wed Nov 01, 2023 7:50 pm
We are using a CCR2116-12G-4S+ as a core gateway and the CCR2004-1G-12S+2XS at a tower site. Using MPLS/VPLS or EoIP tunnels we have discovered that passing traffic from CCR2116-12G-4S+ to CCR2004-1G-12S+2XS gives far better performance than going from CCR2004-1G-12S+2XS to CCR2116-12G-4S+. What I have noticed is that when sending traffic to the CCR2004-1G-12S+2XS , the CCR2116-12G-4S+ uses all of it's CPUs to provide good throughput and the CCR2004-1G-12S+2XS maxes out 2 of it's 4 cpus at 100% but when the traffic comes from the CCR2004-1G-12S+2XS to the CCR2116-12G-4S+ the CCR2004-1G-12S+2XS spreads out the load across all 4 of it's cpus but the CCR2116-12G-4S+ maxes out a single cpu and the throughput is only 1/4 of what it is in the other direction. If I do the same tests between 2 CCR2004-1G-12S+2XS s I get equal bandwidth in both directions and 2 CPUs are maxed out on the receiving end.
So it seems like the CCR2116-12G-4S+ is not multithreaded but the CCR2004-1G-12S+2XS is.
Is this expected or is there maybe a bug in the CCR2116-12G-4S+?
chechito
Re: CCR2116-12G-4S+ worse performance than CCR2004-1G-12S+2XS?
Wed Nov 01, 2023 9:56 pm
i think without:
configs
topology diagram
details of testing procedure
there is not too much to say than guessing
kreb
Thu Nov 02, 2023 4:58 pm
CCR2116 has AL73400 16 cores @ 2000 MHz, Switch chip 98DX3255
CCR2004 has AL32400 4 cores @ 1700 MHz, no switch chip, PIPE 98PX1012 "Passive Intelligent Port Extender"
Theoretically CCR2116 >>> CCR2004
Try 7.12rc4 ,
*) system - fixed process multithreading (introduced in v7.9);
GREGT
Thu Nov 02, 2023 5:50 pm
Thanks for the info kreb.
I wonder if Mikrotik could comment on if that fix would be related to my issue or not.
We are in production with this gateway so I am not eagear to use Beta firmware :(
sirbryan
Thu Nov 02, 2023 6:34 pm
Also, the 2004 uses less CPU if the traffic flow goes from the SFP28 to an SFP+ port (or vice versa). And I've noticed the machine on the receiving end (all other things being equal) ends up using more CPU than the sender, at least for TCP.
GREGT
Sat Nov 04, 2023 5:49 pm
I also see that I have L3 Hw Offloading off and have read several posts that seem to indicate it is unstable. Does anyone know if enabling it may help and if enabling it on a production server will cause any disruption?
Users browsing this forum: No registered users and 5 guests
