I need to catch changed routes and pass this to the notification script. Now I see 2 ways so far:
1. Check immediate-gw. When switching to ISP2 occurs, the /ip route get [find immediate-gw=9.9.9.9%ISP1] command displays "no such item"
2. Catch route flags, if possible in ROS 7. In the case when ISP1 is unavailable and the connection goes through ISP2, the following is displayed:
[admin@Test] > /ip/route/print
Flags: D - DYNAMIC; I - INACTIVE, A - ACTIVE; c - CONNECT, s - STATIC; H - HW-OFFLOADED
Columns: DST-ADDRESS, GATEWAY, DISTANCE
# DST-ADDRESS GATEWAY DISTANCE
;;; ISP2
0 As 0.0.0.0/0 lte1 5
1 IsH 0.0.0.0/0 9.9.9.9 2
2 As 9.9.9.9/32 ISP1 2
DAc 10.11.11.0/24 bridge1 0
DAc 10.100.100.0/24 lte1 0
DAc 172.16.25.1/32 ISP1 0
After the connection to ISP1 is restored, the route flag IsH changes to As:
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, s - STATIC
;;; ISP2
0 s 0.0.0.0/0 lte1 5
1 As 0.0.0.0/0 9.9.9.9 2
Scripting for ROS is not my strong point. I tried writing this, but it doesn't work properly :/
Code: Select all
:if ([/ip route get [find immediate-gw=9.9.9.9%ISP2]]="no such item") do={
:local DeviceName [/system identity get name];
:local ChatID "xxxxxxxxxx";
:local SendText "\E2\9A\A0 <b>Router - $DeviceName:</b>%0AMain ISP on $DeviceName is DOWN!";
#:log info "ISP1 gateway is down";
/tool fetch url="https://api.telegram.org/botxxxxx:xxxxxxxxxxxxxx/sendMessage?chat_id=$ChatID&parse_mode=HTML&text=$SendText" keep-result=no;
