Hi all
New(ish) with Mikrotik and experimenting with several LHGs and a LHGG. The LHGs (latest Router OS and LTE firmware) randomly seem to lose connection to Winbox (ironically still ping and route to internet on the same client device), then don't even appear in the Neighbourhood scan. This can be resolved by resetting to defaults and re-config but I must be doing something wrong. It's like the firewall at some point decides to take a disliking to my local machine. No web console access either
Disabled Windows Firewall on the client just to see, no access
Forced a different client static IP, no access.
Any thoughts?
Cheers
Lea
Update:
All LHGs are second hand, so I held down reset before power up and waited until LEDs flashed then let go, now I've read there are differences between holding reset down before power up and after power up.
From the manual:
RouterBOARD reset button
RouterBOOT reset button has three functions:
Hold this button during boot time until the LED light starts flashing, release the button to reset the RouterOS configuration (total 5 seconds)
Keep holding for 5 more seconds, LED turns solid, release now to turn on CAPs mode (total 10 seconds)
Or Keep holding the button for 5 more seconds until LED turns off, then release it to make the RouterBOARD look for Netinstall servers
If you hold the button before applying power, backup RouterBOOT will be used in addition to all the above actions. To do the above actions without loading the backup loader, push the button right after applying power to the device.
So perhaps all three LHGs are in backup RouterBoot and this isn't normal operation mode and effects neibourhood discovery and Winbox connection after a period of time?
Update:
Reset Mikrotik again ensuring reset button held down after initial power up until LEDs blink, connect with Winbox fine, then I note when I disconnect the client ethernet lead (only have one windows client and one LHG on network, no other devices) and reconnect I lose Winbox and neighbourhood detection.
What on earth am I doing wrong?
