The main differences compared to CSS3xx series switches are: unsupported Independent VLAN Learning;
The wiki https://help.mikrotik.com/docs/display/ ... ies+Manual shows a option: Independent VLAN Look up...But in fact it does not exists. So confused if it will be supported in future.I don’t see how you can read the following quote from the manual any other way than, “If you want IVL, buy a CSS3xx.”
Anything else is wishful thinking.
(As far as I can tell, there is only one current CSS3xx product, but all of the CRS3xx support IVL, too.)
