Tue Apr 09, 2024 12:38 am
this is becoming important, today we found a problem with an eBGP peer with a Huawei or Cisco router at the other end, the debug process shows that they're receiving the cluster-list & originatorid as part of the BGP attributes, which by default makes them discard the routes.
example (from my lab):
Apr 8 2024 21:26:24.280.2 HUAWEI RM/6/RMDEBUG:
BGP.Public : Error identified while receiving UPDATE message from the peer 172.16.x.1 and ignored
Reason: (ORIGINATORID Attribute received from EBGP).
Apr 8 2024 21:26:24.280.3 HUAWEI RM/6/RMDEBUG:
Reason: (CLUSTERLIST Attribute received from EBGP).
Apr 8 2024 21:26:24.280.4 HUAWEI RM/6/RMDEBUG:
BGP: routes in update message need to be processed as withdrawn message due to reason mentioned above.
Apr 8 2024 21:26:24.280.5 HUAWEI RM/6/RMDEBUG:
BGP.Public: Recv UPDATE from 172.16.x.1 with following destinations :
Update message length : 91
MP_reach : AFI/SAFI 1/1
Origin : IGP
AS Path : XXXX YYYY
Next Hop : 172.16.x.1
Community : <aaaa:bbbb>
BGP.Public: Recv UPDATE(Withdraw) MSG from 172.16.x.1 with following destinations :
2.19.162.0/24,
<HUAWEI>
If you peer (using eBGP) with Juniper or any other Mikrotik, it works like charm, haven't tested with other platforms.
This is the log from another Mikrotik (running v6):
05:36:56 route,bgp,debug,packet UPDATE Message
05:36:56 route,bgp,debug,packet RemoteAddress=10.x.x.2
05:36:56 route,bgp,debug,packet MessageLength=91
05:36:56 route,bgp,debug,packet PathAttributes
05:36:56 route,bgp,debug,packet bgp-origin=IGP
05:36:56 route,bgp,debug,packet bgp-as-path=XXXX,YYYY
05:36:56 route,bgp,debug,packet bgp-as-path-len=2
05:36:56 route,bgp,debug,packet bgp-aggregator-as=3427860480
05:36:56 route,bgp,debug,packet bgp-aggregator-address=2.162.19.2
05:36:56 route,bgp,debug,packet bgp-communities={aaaa:bbbb}
05:36:56 route,bgp,debug,packet bgp-originator-id=151355236
05:36:56 route,bgp,debug,packet bgp-cluster-list={ 235372388, 33554432 }
05:36:56 route,bgp,debug,packet NLRI=2.19.162.0/24
The main router sending this updates is a CCR2216 running 7.13.5.
