elico
Caddy reverse proxy with automatic lets encrypt.
Sat Dec 02, 2023 11:37 am
Has anyone tried Caddy reverse proxy with automatic lets encrypt to run ontop of RouterOS container?
It can be pretty nice.
The only issue is the configuration and process management.
A simple port 443 and port 80 port forwarding into the container is a must.
Then the configuration should be auto generated somehow in case you have more than one domain.
I was thinking about caddy api to configure but I don't have much time for this now.
Any suggestions?
A Caddyfile can be:
        email address@example.com
https://sn.example.org {
        reverse_proxy https://172.17.0.1:443 {
                transport http {
                        tls_insecure_skip_verify
https://dom1.example.org {
                transport http {
https://dom2.example.org {
                transport http {
https://dom1.example.com {
                transport http {
vovan700i
Re: Caddy reverse proxy with automatic lets encrypt.
Mon Dec 04, 2023 10:11 am
I use Caddy with automatic LE certificates running on top of RouterOS in container, it works like a charm.
In fact, the only thing I needed for certificates to work is the following lines in config (inside each domain section or separately with imports followed):
tls {
    dns cloudflare MY_TOKEN
Be advised, a stock Caddy doesn't include any DNS verification plugins (Cloudflare, Route53, etc.), thus I use my own build with the plugins I need included. In case you use HTTP verification instead, you should probably refer to Caddy documentation for details/examples.
nickvacula
Thu Dec 14, 2023 10:54 pm
I'm too using Caddy with Let's Encrypt on top of ROS but with Godaddy plugin, not Cloudflare, also custom build, similar to what @vovan700i described above. Work like a charm and I like it!
Note, if you use DNS verification plugin here, your Godaddy API token has a secret and a key, you just specify them both via semicolon:
tls {
	dns godaddy YOUR_GODADDY_SECRET:YOUR_GODADDY_KEY
Users browsing this forum: No registered users and 1 guest
