Dear team,
i have RB2011uigs-rm router that connects access points, switches through lan port with local lan on 192.168.1.1/24 and WAN connected to SFP port.
the yeaster IP/PBX is running on static IP address and the remaining devices are on DHCP.
i have done all nececssary configuration for port forwarding as per the instruction manual from yeaster for mikrotik.
the issue we are facing is the packets are dropping as well as for SIP. after contacting the yeaster support, they suggest we look into mikrotik router configuration.
atttached are the screen shot of the log. any help would be appriciated.
awaiting for reply.
mohammed
