Hello MikroTik team,
is there any reason why are you doing PoE in/out at the same port on ax devices?
For example hAP ax2 and hAP ax3 has this IMHO "most stupid idea ever"
Is there any technical (not economic) reason for that? If it's purely for economical reason, what's would be the price difference between POE/in on 1st port, PoE out on 5th vs. in/ou at the same port?
I would rather have some EUR more expensive device, but with separate PoE in/out...
Something like old, good hAP ac but upgraded to ax. It means 1 SFP/SFP+/QSFP port, 5 Ethernet ports with separated PoE in and out and 2 Wireless interfaces (2.4 + 5/6 GHz).
Will you at least think about a product like that?
