Before I open a ticket with Mikrotik can anybody see if I have done something wrong in below config?
PROBLEM
The TeamCYMRU_V4 Peer does not initiate connections neither does it respond to the connections coming in from TeamCYMRU. Peer never comes up. The other two peers to my upstreams are working fine. I have had somebody else check the MD5 Key.
No amount of rebooting, disabling, enabling, deleteing and readding helps. I have even upgraded to 7.12.1 before I would have preferred to. The ip address given is a loopback address on a bridge interface.
Peer / Connection
Code: Select all
name="TeamCYMRU_v4"
remote.address=216.31.3.81/32 .as=65332
local.default-address=160.119.217.104 .role=ebgp
tcp-md5-key="****" connect=yes listen=yes routing-table=main router-id=160.119.217.104 templates=Fullbogons as=328162
multihop=yes address-families=ip
output.affinity=main
input.affinity=main .filter=Fullbogons
Code: Select all
chain=Fullbogons rule="if (bgp-communities includes 65332:888) { reject;}"
Code: Select all
CYMRU-IN input: in:ether4 out:(unknown 0), connection-state:new src-mac 5c:b1:2e:b3:94:17, proto TCP (SYN), 216.31.3.81:59260->160.119.217.104:179, len 64ode]
Help much appreciated.
Alex
