Hello there,
This is my first project so in advance thanks for patience and sorry for stup. questions...
I bought LTE Cat4 module Quectel EC200A-EU and conenct it to my mikrotik RBM11G.
Over winox this mpcie card shows as "Android" device.
How to connect correctly this card? I have tryed tape USB3.0 pins but also there is same result
I don't know what to do, this card is with same LTE module as Mikrotik's modul R11eL-EC200A-EU... so RB must have driver for this Quectel card
Can you help me with this please?
In advance thanks for help
Martin
PS. attached screenshot of of stuff from winbox
PS2. what is the usual procedure to set up the card correctly? Do I need to setup card directly from PC over any SW or it's not needed
UPDATE:
firstly updated to 6.49 -> it doesn't help
then updated to ROSv7 and it works perfectly
