spr41178
RB5009 Power Issue
Fri Dec 15, 2023 3:44 pm
Hello Team,
I am facing an issue with my RB5009 and wondering if anyone else has faced anything similar.
After an upgrade or a power failure or a power loss the router fails to startup.
You have to manually remove the power and start it again and everything works fine after that.
Any ideas?
Thank you.
mkx
Re: RB5009 Power Issue
Fri Dec 15, 2023 5:07 pm
Is your router running a recent ROS version (7.12.1 was stable for some time, 7.13 is newly released in stable). Is routerbot also upgraded (/system/routerboard)?
andkar
Fri Dec 15, 2023 5:32 pm
External storage?
From 7.13 changelogs:
*) disk - fixed hang on reboot when network file systems mounted;
draxlerzoltan
Mon Dec 18, 2023 10:26 pm
Hello.
I have a similar situation; my RB5009 also restarts as if there was a power outage (the device is connected to an online UPS). Downgrading to version 7.12.1 solves the issue. I hope they fix it soon.
challado
Mon Feb 05, 2024 2:59 pm
Me too.
Several POWER OUTAGES on log without any explanation. I have switched power supply, power it over ethernet, with no success.
RSE
Wed Feb 28, 2024 11:09 am
Same for me but on version v7.13.5
I never had this before v7.13 the router just randomly reboots as if power went out. any solutions?
holvoetn
Wed Feb 28, 2024 1:02 pm
Everyone reporting the issue:
have you made supout.rif right after the reboot (or use autosupout if it was generated) and made a ticket with support with supout included ?
FWIW I don't see this issue on 2 RB5009's I have.
One on 7.14rc2, the other is on 7.13.3.
Users browsing this forum: faxxe, mstanciu, Semrush [Bot] and 24 guests
