I have RB4011 router in my home as main router and 2 CAP AC XL for upstairs and downstairs. They connected the rb4011 with directly. My ISP provides 1000/100mbps. i can reach 950mbps download speed with cable.
I enabled the capsman it recognize the radios. Even though I set 80 mhz bandwidth and am only 50 cm away from the access point, the download speed does not exceed 350mbps. My tested clients are iphone 14 pro max and Asus B650E-F Gaming builtin wifi.What is the problem? Currently there is more than one channel in 5ghz channels, but the result did not change even when I try only one channel.
My Capsman config like this:
# 2023-12-21 17:25:15 by RouterOS 7.12.1
# software id = WDL2-L484
# model = RB4011iGS+
# serial number = B8F30B0E63D6
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2462 name=ch11
add band=5ghz-n/ac control-channel-width=20mhz extension-channel=eeCe frequency=5540 name=ch106
add band=5ghz-n/ac control-channel-width=20mhz extension-channel=eCee frequency=5280 name=ch58
add band=5ghz-n/ac control-channel-width=20mhz extension-channel=Ceee frequency=5580 name=ch122
add band=5ghz-n/ac control-channel-width=20mhz extension-channel=eeCe frequency=5220,5300,5540 name="ch42, ch58, ch106"
/caps-man datapath
add bridge=bridge name=datapath1
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=home_key
add authentication-types=wpa2-psk encryption=aes-ccm name=guest_key
add authentication-types=wpa2-psk encryption=aes-ccm name=smart_key
/caps-man configuration
add channel=ch11 country=turkey datapath=datapath1 installation=any mode=ap name=home_2.4 security=home_key ssid="EFE's Home"
add channel=ch11 country=turkey datapath=datapath1 installation=any mode=ap name=guest_2.4 security=guest_key ssid="EFE's Home Guest"
add channel=ch11 country=turkey datapath=datapath1 installation=any mode=ap name=smart_2.4 security=smart_key ssid="EFE's Smart Home"
add channel="ch42, ch58, ch106" country=turkey datapath=datapath1 installation=any mode=ap name=home_5 security=home_key ssid="EFE's Home"
add channel="ch42, ch58, ch106" country=turkey datapath=datapath1 installation=any mode=ap name=guest_5 security=guest_key ssid="EFE's Home Guest"
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=home_2.4 name-format=prefix name-prefix=2.4g_ slave-configurations=smart_2.4,guest_2.4
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=home_5 name-format=prefix name-prefix=5g_ slave-configurations=guest_5
