Our upgrade to v7.13 broke BGP. I'm including the BGP config for three routers at the end. Router #1 is the gateway router. Router #1 and Router #3 run fine with router #2 on v6.
Issue at Router #1:
Router #1 has a bad route to 10.2.14.0/24 advertised by the downstream router. In winbox it shows: Dst: 10.2.14.0/24 Gateway: 198.245.193.230 recursive via 198.245.193.241 sfp-sfpplus1. I would expect it to route to 198.245.193.230 for dst of 10.2.14.1, but it's routing to 198.245.193.241, which is the default gateway.
Issue at Router #3:
Router #3 is not receiving a default gateway address unless Router #2 is configured with default-originate=always. on v6, I had default-originate=if installed
I also had trouble with filters, but the work-around was to disable them. This is what they looked like after the upgrade to v7.
/routing filter rule
add chain=primary disabled=no rule="set distance 10; set bgp-local-pref 100;"
add chain=secondary disabled=no rule="set distance 20; set bgp-local-pref 70;"
#Router #1 (v6.49.10)
/routing bgp instance
set default out-filter=bgp-out redistribute-static=yes
add as=65001 name=ncresa redistribute-other-bgp=yes router-id=0.0.0.1
/routing bgp peer
add default-originate=always hold-time=10s instance=ncresa keepalive-time=3s \
name=ncresa remote-address=198.245.193.226 remote-as=65001 ttl=default
#Router #2 (v6.49.10) Working
add as=65002 name=test redistribute-other-bgp=yes redistribute-static=yes \
router-id=0.0.0.2
add as=65001 name=ncresa redistribute-other-bgp=yes redistribute-static=yes \
router-id=0.0.1.1
/routing bgp peer
add hold-time=10s in-filter=primary instance=ncresa keepalive-time=3s name=\
ncresa remote-address=198.245.193.225 remote-as=65001 ttl=default
add default-originate=if-installed hold-time=10s in-filter=secondary \
instance=test keepalive-time=3s name=test remote-address=198.245.193.230 \
remote-as=65002 ttl=default
#Router #2 (v7.13) Not Working
/routing bgp template
add as=65001 disabled=no name=ncresa output.network=bgp-networks \
.redistribute=static,bgp,vpn,dhcp router-id=0.0.0.2
add as=65002 disabled=no name=ncresa-e output.network=bgp-networks \
.redistribute=static,vpn,dhcp router-id=0.0.1.1
/routing bgp connection
add as=65001 cisco-vpls-nlri-len-fmt=auto-bits connect=yes disabled=no \
hold-time=10s keepalive-time=3s listen=yes local.role=ibgp name=ncresa \
output.default-originate=if-installed .network=bgp-networks \
.redistribute=static,bgp remote.address=198.245.193.225/32 .as=65001 \
.port=179 router-id=0.0.0.2 routing-table=main templates=ncresa
add as=65002 cisco-vpls-nlri-len-fmt=auto-bits connect=yes disabled=no \
hold-time=10s keepalive-time=3s listen=yes local.role=ibgp name=test \
output.default-originate=always .network=bgp-networks .redistribute=\
static remote.address=198.245.193.230/32 .as=65002 .port=179 router-id=\
0.0.1.1 routing-table=main
Router #3 (v6.49.10)
add as=65002 name=ncresa redistribute-other-bgp=yes redistribute-static=yes \
router-id=0.0.14.1
/routing bgp network
add network=10.2.14.0/24
add network=198.245.193.228/30
/routing bgp peer
add hold-time=10s instance=ncresa keepalive-time=3s name=ncresa \
remote-address=198.245.193.229 remote-as=65002 ttl=default
