FrozenPizza
hAP ax ?
Sun Dec 31, 2023 10:17 pm
Will hAP ac be updated to ax at some point or is the case too small? We have situations where need drop in replacement. First we use RB951G, then we use hAP ac, but now we want to use hAP ax, identical footprint chassis.
Thanks!
holvoetn
Re: hAP ax ?
Sun Dec 31, 2023 11:59 pm
Nope.
There is ax lite, ax2, ax3.
All different packages.
FrozenPizza
Re: hAP ax ?
Thu Jan 04, 2024 12:09 am
Nope.
When I say hAP ac I am referring to RB962UiGS-5HacT2HnT
How you know for sure they won't update hAP ac to hAP ax?
holvoetn
Re: hAP ax ?
Thu Jan 04, 2024 8:59 am
There is already hAP ax2 and ax3.
There is almost zero added value for another model with same capabilities but other package, it just adds costs.
What you're loosing now is USB (ax3 has it but package is TOTALLY different) and SFP port.
So maybe, with time, something might come. But I am not so sure or it would already have been done.
phascogale
Re: hAP ax ?
Thu Jan 04, 2024 10:13 am
If MikroTik had wished to reproduce the hAP ac form factor as an AX device, why would they not already have done so rather than investing in design of the hAP ax2? Have you considered there may have been heat issues in such an attempt (look at the ax2)?
Maybe that form factor can or will be reiterated as an AX in the future. Waiting would not be my preferred strategy.
kalamaja
Re: hAP ax ?
Thu Jan 04, 2024 10:24 am
If the size is important for you then there's hAP AX2. hAP AC's main feature was 3-chain WiFi for both 2.4 and 5GHz, it was the case at times when Macbook Pros could really use it, but they also went back to 2-chain and now AX gives you the extra speed.
If the "white block form" is important to you then IIRC hAP AC2 could be screwed into old white boxes, AX2 is similar, but don't know the details.
FrozenPizza
Re: hAP ax ?
Sun Jan 07, 2024 7:44 pm
There is hAP ac³ and hAP ac² in addition to the hAP ac, so saying that there is already an hAP ax² and hAP ax³ so why do you need hAP ax is sort of a strange argument IMO
We really like the white box of RB951G / hAP ac. hopefully I can wait it out and Mikrotik will eventually sell off all of their hAP ac stock and update it
Maybe they are just sitting on lots of hAP ac units they need to get rid of first.
normis
Re: hAP ax ?
Mon Jan 08, 2024 10:43 am
Same like saying you'd like the new engine and interior, but keep the 2001. design of a car.
Sorry, we do not plan to use the old cases for the AX series
Rox169
Re: hAP ax ?
Mon Jan 08, 2024 10:50 am
No problem but please learn from your mistakes how to change design to worse...CUBE PRO - water inside.
Users browsing this forum: ringrring and 16 guests
