kusterh
Dude trying to login via winbox every hour
Tue Jan 02, 2024 11:48 am
I recently enabled dude on my RB5009 router (7.13 ros) to monitor my network (with several hap ax3 ap's and some switches).
My router has 3 networks 10.0.0.0/24, 10.0.1.0/24 and 10.0.2.0/24, and is reachable on address .1 in each of these networks, but I only allow access to winbox from network 10.0.0.0/24.
Somehow Dude is trying to login every hour via winbox on the other networks (see screenshot below), but I cannot find where this is configured. I checked all server settings for polling and the settings for the devices (10.0.1.1 and 10.0.2.1) for their services and disabled winbox for both.
But still this faililng login every hour is happening, anyone a clue where I can disable this ?
bpwl
Re: Dude trying to login via winbox every hour
Tue Jan 02, 2024 12:02 pm
Potential reasons for DUDE connecting to RouterOS ... via WinBox
Your RB5009 will probably show multiple IP and MAC addresses in DUDE
And I see connect from ... means ... multiple DUDE outgoing addresses
kusterh
Tue Jan 02, 2024 3:25 pm
Ah, your screenshot pointed me in another direction (not really sure yet if this is the correct direction ;)).
I've now added the other two ip-adresses to my router device (so it now has 3 ip-adresses associated with 1 device), and I deleted the other two 'auto-discovered' devices.
Going to see if now the hourly login try of dude onto these other two ip-adresses are now gone.
kusterh
Tue Jan 02, 2024 5:38 pm
Well, the change I did above didn't help, also when I assign the three ip-adresses in dude to my router device I still get the hourly failing log-in message on my router from .1.1 and .2.1
Any other idea's where to look in dude settings so it's not going to try and login to winbox on (or via ?) these other two ip adresses ?
stmx38
Long time Member
Long time Member
Wed Jan 03, 2024 7:30 pm
Dude uses Winbox port for authentication. What do you have in your Dude Settings?
kusterh
Thu Jan 04, 2024 10:35 am
My settings are equal to your screenshot (just the default settings of 1m and 1d), so this should not cause the login every hour I would guess.
Users browsing this forum: No registered users and 14 guests
