Hi together, I run a following setup:
- RB5009UPr+S+ as the main router + capsman
- hap ax3 as a cap
- hap ax2 as a cap
All of the sudden, around new year, the hap ax2 has stopped airing wifi. When I look into the status of wifi interface, the state is "Disabled" although it has run a DFS Scan and shows itself being managed by the capsman.
The hap ax3 with almost identical config runs just fine
Could someone please look into the configuration as I am not able to find an issue? Could this be a hardware defect? I have tried performing a factory reset etc., yet had no success of bringing the interface on air
capsman (MAC and so on redacted for privacy):
/interface wifi channel
add band=2ghz-ax disabled=no name=ch-2ghz width=20/40mhz
add band=5ghz-ax disabled=no name=ch-5ghz width=20/40/80mhz
/interface wifi datapath
add bridge=bridge_lan disabled=no interface-list=LAN name=datapath-lan
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-mobility-domain=0xADC4 ft-nas-identifier=8b1a9953c4611296a827abf8c47804d7 ft-over-ds=yes ft-r0-key-lifetime=7h ft-reassociation-deadline=20s name=Home-Sec wps=disable
/interface wifi configuration
add channel=ch-5ghz country=Germany datapath=datapath-lan disabled=no mode=ap name=Home-5G security=Home-Sec security.connect-priority=0 ssid=SSID
add channel=ch-2ghz country=Germany datapath=datapath-lan disabled=no hide-ssid=no mode=ap name=Home-2G security=Home-Sec security.connect-priority=0 ssid=SSID
/interface wifi
add configuration=Home-5G disabled=no name=wifi3 radio-mac=48:A9:8A
add configuration=Home-2G disabled=no name=wifi4 radio-mac=48:A9:8A
add configuration=Home-5G disabled=no name=wifi5 radio-mac=48:A9:8A
add configuration=Home-2G disabled=no name=wifi6 radio-mac=48:A9:8A
/interface wifi steering
add disabled=no name=steering1 neighbor-group=Zuhause rrm=yes wnm=yes
/interface wifi cap
set caps-man-addresses=10.100.10.1 certificate=none discovery-interfaces=bridge_lan enabled=yes
/interface wifi capsman
set ca-certificate=CAPsMAN-CA-789A1870292F certificate=CAPsMAN-789A1870292F enabled=yes interfaces=bridge_lan package-path="" require-peer-certificate=no upgrade-policy=require-same-version
/interface wifi provisioning
add action=create-enabled disabled=no master-configuration=Home-5G name-format="" supported-bands=5ghz-ax
add action=create-enabled disabled=no master-configuration=Home-2G name-format="" supported-bands=2ghz-ax
cap ax3 (working):
add admin-mac=48:A9:8A:0D:3C:06 auto-mac=no comment=defconf name=bridge_lan \
port-cost-mode=short
add bridge=bridge_lan comment=defconf disabled=no name=capdp
/interface wifi
# managed by CAPsMAN
# mode: AP, SSID: SSID, channel: 5500/ax/Ceee
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap datapath=\
capdp disabled=no
# mode: AP, SSID: SSID, channel: 2412/ax/Ce
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap datapath=\
capdp disabled=no
add bridge=bridge_lan comment=defconf interface=ether1 internal-path-cost=10 \
path-cost=10
add bridge=bridge_lan comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge_lan comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge_lan comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge_lan comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge_lan interface=wifi1 internal-path-cost=10 path-cost=10
add bridge=bridge_lan interface=wifi2 internal-path-cost=10 path-cost=10
/interface wifi cap
set caps-man-addresses=10.100.10.1 certificate=request discovery-interfaces=all \
enabled=yes
add address=10.100.10.3/24 interface=bridge_lan network=10.100.10.0
/ip dhcp-client
add comment=defconf interface=bridge_lan
/system clock
/system identity
set name=DE-FRA-W45-CAP1
/system note
set show-at-login=no
cap ax2 (not working):
- when I open the status tab on in winbox, the state is "Disabled" and there is in fact also no signal coming out
- also, I had to change the certificate to "none", otherwise it would just show "no connection to capsman" and had to turn off certificate requirement on the capsman as well in order to get it work even slightly. I can rule out firewall issues as I have tried temporarily disabling all blocking rules, however I still got the "no connection to capsman" error. Setting the certificate to none got it working again
add admin-mac=48:A9:8A:66:3D:DF auto-mac=no comment=defconf name=bridge_lan \
/interface wifi
capdp disabled=no
# mode: AP, SSID: SSID, channel: 2462/ax/eC
capdp disabled=no
path-cost=10
path-cost=10
path-cost=10
path-cost=10
path-cost=10
add bridge=bridge_lan interface=*6 internal-path-cost=10 path-cost=10
/interface wifi cap
set caps-man-addresses=10.100.10.1 certificate=none discovery-interfaces=all \
enabled=yes
add address=10.100.10.2/24 interface=bridge_lan network=10.100.10.0
/ip dhcp-client
/system clock
/system identity
set name=DE-FRA-W45-CAP-Abstellraum
/system note
The devices have also been updated to the latest 7.13.1 and have all the "wifi-qcom" package, even the RB5009UPr.
I am really losing my mind over this.
