Hi guys, i don't know much about network configuration at all, thats my first timing setting a a captive portal and i found some troubles.
On the company network, I have a MikroTik as the default gateway, which is connected to a switch where devices are wired and receive IP addresses via DHCP from the MikroTik in the 192.168.1.0/24 network. For Wi-Fi, I use pfSense with a captive portal.
The pfSense has the IP address 192.168.1.204, its WAN interface is in the 192.168.1.0/24 network, and its LAN interface is in the 192.168.50.0/24 network. PfSense assigns IP addresses via DHCP to clients connected to Wi-Fi.
The networks can communicate with each other, but there is a significant drop in speed when traffic goes from the 192.168.1.0 to the 192.168.50.0 network. Additionally, network discovery does not work correctly. Printers and Wi-Fi cameras cannot be discovered by devices connected directly to the MikroTik, and when configured manually, they work but with extremely low speed.
Firewall rules are configured directly on the MikroTik, with pfSense used solely as a captive portal and for logging user activity.
Any ideas why this happen?
