Josephny
Export non-DHCP devices
Thu Jan 11, 2024 6:39 pm
In another thread ( viewtopic.php?p=1047561#p1047561 ) I sought and received helped that allowed me to create a script to export all DHCP leases with comment, in CSV.
I then used a Windows Powershell script to concatenate and clean up the files from the individual MT devices.
I can now open this file directly into Excel. Here is just one page of it:
Can someone suggest how to go about collecting non-DHCP-IP-assigned devices? (To be clear, I mean devices where the IP is set on the device; the DHCP server has no clue about them.)
I thought about using the output from IP-scan or packetsniff or arp, but not sure which would be smarter.
There would also be the need to bring along with the IP address any associated info such as MAC-address, host-name, DNS-name.
Thank you.
Josephny
Re: Export non-DHCP devices
Fri Jan 12, 2024 7:57 pm
Do I ask too much?
rextended
Sat Jan 13, 2024 10:19 am
Do I ask too much?
Hire someone, it's a job, not a command to explain...
Jotne
Sun Jan 14, 2024 12:35 am
It can be done by comparing arp table with DHCP table. But you will not see IP that do not communicate with or trough the router.
Josephny
Sun Jan 14, 2024 2:47 am
Thank you guys.
/ip/arp/print detail does not show hostname (or bridge port).
Jotne
Sun Jan 14, 2024 11:17 am
In Winbox
Bridge -> Hosts
In Cli
/interface/bridge/host/print
You will see MAC, Interface, Bridge and VLAN for each device.
Then you can mix that together with the \ip\arp\print to get IP for the mac.
Josephny
Tue Jan 16, 2024 11:23 am
Thank you.
What I really need is:
MAC
IP
HOSTNAME
Would be nice to also have:
DNS-name
Bridge Port
Is there a single table available that includes all of these?
Users browsing this forum: No registered users and 5 guests
