I moved from hap ac2 to hap ax2 - unfortunately, the wifi coverage dropped dramatically - where I had a signal strength of 60-65, I have 70-78... can someone explain to me what is happening and why?
Code: Select all
2 M BR default-name="wifi1" name="wifi1" l2mtu=1560 mac-address=[MAC] arp-timeout=auto radio-mac=[MAC]
configuration.mode=ap .ssid="some ssid" .antenna-gain=0
security.authentication-types=wpa2-psk,wpa3-psk .passphrase="XXXXXX" .connect-priority=0
channel.frequency=5260 .band=5ghz-ax .width=20/40/80mhz .skip-dfs-channels=disabled
Now in some parts of the apartment, e.g. phones do not connect to Wi-Fi at all. On AC2, the coverage was ok everywhere.
Thank you in advance - if you need any information, let me know
link to wifi analizer screenshot https://postimg.cc/gallery/HcLx3HL - of course, the location of the router was the same.
