Here's an edited export of my /interface/wifi config section:
Code: Select all
/interface wifi channel
add disabled=no frequency=2412 name=channel1 width=20mhz
add disabled=no frequency=2437 name=channel6 width=20mhz
add disabled=no frequency=2462 name=channel11 width=20mhz
add disabled=no frequency=5180 name=channel36 width=20/40/80mhz
add disabled=no frequency=5260 name=channel52-dfs width=20/40/80mhz
add disabled=no frequency=5660 name=channel132-dfs width=20/40/80mhz
add disabled=no frequency=5745 name=channel149-opt width=20/40/80mhz
/interface wifi security
add authentication-types=wpa2-psk disable-pmkid=yes disabled=no ft=yes ft-over-ds=yes group-encryption=ccmp group-key-update=40m management-protection=allowed name=default wps=disable
/interface wifi configuration
add disabled=no name=cfg-2ghz security=default security.ft=yes .ft-over-ds=yes ssid=XXX
add disabled=no name=cfg-5ghz security=default security.ft=yes .ft-over-ds=yes ssid="XXX (5G)"
add disabled=no name=cfg-5ghz-YY security=default ssid="YYY (5G)"
/interface wifi
add channel=channel6 configuration=cfg-2ghz configuration.mode=ap .tx-power=13 disabled=no name=2GHz-Room2Router-1 radio-mac=XX:XX:XX:XX:XX:X1
add channel=channel11 configuration=cfg-2ghz configuration.mode=ap .tx-power=10 disabled=no name=2GHz-Room3Router-1 radio-mac=XX:XX:XX:XX:XX:X2
add channel=channel132-dfs configuration=cfg-5ghz configuration.mode=ap .tx-power=13 disabled=no name=5GHz-Room2Router-1 radio-mac=XX:XX:XX:XX:XX:X3
add channel=channel52-dfs configuration=cfg-5ghz configuration.mode=ap .tx-power=13 disabled=no name=5GHz-Room3Router-1 radio-mac=XX:XX:XX:XX:XX:X4
add channel=channel149-opt configuration=cfg-5ghz configuration.mode=ap .tx-power=13 disabled=no name=5GHz-Room3Router-2 radio-mac=XX:XX:XX:XX:XX:X5
/interface wifi datapath
add bridge=bridge disabled=no name=capdp
/interface wifi
set [ find default-name=wifi1 ] channel=channel1 configuration=cfg-2ghz configuration.mode=ap .tx-power=10 datapath=capdp disabled=no name=2GHz-Firewall-1
set [ find default-name=wifi2 ] channel=channel36 configuration=cfg-5ghz configuration.mode=ap .tx-power=13 datapath=capdp disabled=no name=5GHz-Firewall-1
add configuration=cfg-5ghz-YY configuration.mode=ap datapath=capdp disabled=no mac-address=XX:XX:XX:XX:XX:X6 master-interface=5GHz-Firewall-1 name=5GHz-Firewall-1-1
/interface wifi capsman
set ca-certificate=auto enabled=yes interfaces=bridge require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-enabled disabled=no master-configuration=cfg-5ghz name-format=5GHz-%I supported-bands=5ghz-n
add action=create-enabled disabled=no master-configuration=cfg-2ghz name-format=2GHz-%I supported-bands=2ghz-n
add action=none disabled=no
