tomog
Filters in iBGP v7 loopback
Fri Jan 12, 2024 3:20 pm
hello, can anyone check the correctness of the filters ? v7 version for iBGP
after the internal ip address works, does not work after the external one
on v6 version works correctly
0 X ;;; KATOWICE 205 Slave
chain=IN-iBGP1
rule="if (dst in 0.0.0.0/0 && dst-len == 0) { set distance 205; set bgp-local-pref 300; accept; }"
1 X ;;; KATOWICE 190 MASTER
chain=IN-iBGP1
rule="if (dst in 0.0.0.0/0 && dst-len == 0) { set distance 190; set bgp-local-pref 400; accept; }"
2 ;;; KATR
chain=IN-iBGP1
rule="if (dst-len==0 && dst in 0.0.0.0/0) { set distance 190; set bgp-local-pref 400; accept; }"
3 chain=IN-iBGP1 rule="reject"
4 chain=OUT-iBGP1 rule="if (dst-len>30 && dst-len<32 && dst in IP ADRESS) { reject }"
5 chain=OUT-iBGP1 rule="if (dst-len==32 && dst in IP adress ) { accept }"
6 chain=OUT-iBGP1 rule="if (dst-len==32 && dst in IP ADRESS) { accept }"
7 chain=OUT-iBGP1 rule="reject;"
8 X chain=OUT-iBGP1 rule="if (dst in IP ADRESS/31 && dst-len in 30-32) { reject; }"
9 X chain=OUT-iBGP1 rule="if (dst in IP ADRESS/24 && dst-len == 32) { accept; }"
10 X chain=OUT-iBGP1 rule="if (dst in IP ADRESS0/24 && dst-len == 32) { accept; }"
11 X ;;; WAR
chain=IN-iBGP2
12 X ;;; WARSZAWA 205 Slave
chain=IN-iBGP2
13 ;;; WARSZAWA 205 Slave
chain=IN-iBGP2
rule="if (dst-len==0 && dst in 0.0.0.0/0) { set distance 205; set bgp-local-pref 300; accept; }"
14 chain=IN-iBGP2 rule="reject;"
15 chain=OUT-iBGP2 rule="if (dst-len>30 && dst-len<32 && dst in IP ADRESS/31) { reject }"
16 chain=OUT-iBGP2 rule="if (dst-len>30 && dst-len<32 && dst in IP ADRESS/31) { accept }"
17 chain=OUT-iBGP2 rule="if (dst-len==32 && dst in IP ADRESS/24) { accept }"
18 X chain=OUT-iBGP2 rule="if (dst in IP ADRESS31 && dst-len in 30-32) { reject; }"
19 X chain=OUT-iBGP2 rule="if (dst in IP ADRESS24 && dst-len in 30-32) { accept; }"
20 X chain=OUT-iBGP2 rule="if (dst in IP ADRESS/24 && dst-len == 32) { accept; }"
21 chain=IN-IBGP-NAT rule="if (dst in IP ADRESS/8 && dst-len in 8-32) { accept; }"
22 chain=IN-IBGP-NAT rule="if (dst in IP ADRESS/16 && dst-len in 16-32) { accept; }"
23 chain=IN-IBGP-NAT rule="if (dst in IP ADRESS/10 && dst-len in 10-32) { accept; }"
24 chain=IN-IBGP-NAT rule="if (dst in IP ADRESS/12 && dst-len in 12-32) { accept; }"
25 chain=IN-IBGP-NAT rule="if (dst in IP ADRESS/16 && dst-len in 16-32) { accept; }"
26 chain=IN-IBGP-NAT rule="reject;"
27 chain=OUT-IBGP-NAT rule="if (dst in IP ADRESS/8 && dst-len in 8-32) { accept; }"
28 chain=OUT-IBGP-NAT rule="if (dst in IP ADRESS16 && dst-len in 16-32) { accept; }"
29 chain=OUT-IBGP-NAT rule="if (dst in IP ADRESS/10 && dst-len in 10-32) { accept; }"
30 chain=OUT-IBGP-NAT rule="if (dst in IP ADRESS/12 && dst-len in 12-32) { accept; }"
31 chain=OUT-IBGP-NAT rule="if (dst in IP ADRESS/16 && dst-len in 16-32) { accept; }"
32 chain=OUT-IBGP-NAT rule="reject;"
Users browsing this forum: NxtGen [Bot] and 6 guests
