Josephny
ip-scan
Tue Jan 16, 2024 4:08 pm
Is there a way to save the output of ip-scan executed from a script?
optio
Long time Member
Long time Member
Re: ip-scan
Tue Jan 16, 2024 7:23 pm
Add additional command argument as-value and output then can be passed to variable or other command argument. It will not be same output as printed on CLI, as-value returns key-value array, but that can be formatted for some file output if needed.
Josephny
Re: ip-scan
Wed Jan 17, 2024 12:28 am
Thank you but I don't know how to work with as-value.
I tried researching, but the explanations are of limited use.
optio
Long time Member
Long time Member
Re: ip-scan
Wed Jan 17, 2024 7:32 pm
Example:
:local filename "scan.txt"
:local records ""
:foreach scan in=[/tool/ip-scan duration=10s as-value] do={
  :local record "IP: $($scan->"address"), MAC: $($scan->"mac-address")"
  :put $record
  :set records "$records$record\n"
:if ([:len records] > 0) do={
  /file
  :if ([:tobool [find where name=$filename]]) do={
    remove $filename
  add contents="IP scan records:\n$records" name=$filename
this will iterrate key-value array from command
result (modify this depending on your needs), print records in CLI and if records are populated (if ip-scan command did found some addresses) will save to (overwrite) file named in filename variable (scan.txt) with content header "IP scan records:\n" (you can change this in add contents=... command).
Key-value array from this ip-scan result can contain values in keys:
address
dns
mac-address
netbios
and
snmp
, you can modify record string variable in format depending on your needs and what you want to extract for each scan record (example uses only values from address and mac-address keys).
Users browsing this forum: No registered users and 6 guests
