Tried to install new wifi-qcom-ac-7.13.2-arm.npk to test it with my cAP ac devices, but came across with inability of setting country.
Tried it via winbox and cli.
But getting errors --failed to set country and --country locked, using
- cAP ac (International) supports 2412-2484MHz and 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
- cAP ac-US (USA) is factory locked for 2412-2462MHz, 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
/interface/wifi/ export file=anynameyoulike
That error indication already shows where the problem might be.
Is that device effectively country locked ?
In that case you will not be able to change it.
What model is being shown on the label ?
Were you able to change country before moving to 7.13 and qcom-ac driver ?
Here is the config I used basic config from guideRemove current wifi configuration and start again.
And perhaps you can share your current config:
Code: Select all/interface/wifi/ export file=anynameyoulike
On the label i see following:What model is being shown on the label ?
Hello!Do let us know how it goes.
