I have several sonoff diveices which worked well on the 2.5 netowrk. Now I reorganized the network putting 4 Mikrotik devices ( 2xRBwAPG-5HacD2HnD+RB95Ui-5ac2nD+RBcAPGi-5acD2nD ) in a mesh with CAPsMAN. All are sending in both 2.5 and 5 frequencies.
I put a MAC filtering using the access list on the CAPsMAN server, with ACCEPT from any and MAC for all allowed devices, with a final 00:00:00:00:00:00 reject rule.
Everything well, phones, tablets and so on go well, so do most SONOFF devices on 2.5 WIFI.
But two or three sonoff devices di not connect with the reject rule. If I put the 00:00:00:00:00:00 rule to accept, they connect. I checked the MAC several times.
Even more weird is that first a new device did this, than trying more than ten times it stayed connect, but now other two devices go off line when i put the reject rule.
So: If I turn off MAC control il connects, if I turn on MAC control it goes of, MAC numbers controlled and corresponding.
total rules: 54
some suggestion?
