ianiovski
Problem RB960PGS and UPS APC BX1600MI-GR
Sat Jan 20, 2024 5:21 pm
Hello, I have a monitoring problem between RB960PGS and UPS APC BX1600MI-GR. The router sees the UPS and shows its parameters, but in the Mikrotik logs it constantly spits out UPS Power on and then Power off for a minute. I think that the problem is something in the communication, because the USB of UPS is 1.10, and of RB it is 2.0. I read in the forum, the communication problem was solved with a simple Usb Hub 2.0, I bought one, but the result is the same. I wanted to have monitoring on it, and that was one of my important requirements when buying the UPS, but that's exactly what didn't work as it should.
Users browsing this forum: ismel0x, johndol and 39 guests
