ikiris
wireguard /31 with edgerouter ospf failling to establish peer
Sat Jan 20, 2024 6:03 pm
Greetings,
I'm trying to slowly migrate away from an existing edgerouter setup to a mikrotik one, and have point to point 0/0, ::0/0 /31 tunnels established just fine between the existing network running ospf for link state, with bgp connecting loopbacks.
When I added the mikrotik in, the peers try to establish, but never complete and I'm trying to figure out which side has the ospf bug here (leaning towards mikrotik here since I've made this work with other devices as well like ciscos / opnsense). I'd look at the packet exchange, but trying to get a clean packet dump from an encrypted tunnel on the wan side isn't exactly easy.
From what I see, the nodes see each other's hellos, and begin exchange, but the mikrotik side never sees the DD reply from the far side so it just continually fails to establish and times out.
What am I missing here, or did I find a bug in how mikrotik (or the edgerouters) are adhering to the OSPF RFCs?
Relevant log bits from ospf debug mikrotik side:
09:47:17 route,ospf,packet ospf_v2 { version: 2 router-id: 192.168.50.1 } backbone_v4 { 0.0.0.0 } interface { p2p 192.168.17.2%wg1 } neighbor { router-id: 192.168.50.2 state: Exchange } receive DD from 192.168.17.3 Init Master More sequence 3202
09:47:17 route,ospf,packet ospf_v2 { version: 2 router-id: 192.168.50.1 } backbone_v4 { 0.0.0.0 } interface { p2p 192.168.17.2%wg1 } neighbor { router-id: 192.168.50.2 state: Exchange } send DD to 192.168.17.3 sequence 3202
09:47:22 route,ospf,packet ospf_v2 { version: 2 router-id: 192.168.50.1 } backbone_v4 { 0.0.0.0 } interface { p2p 192.168.17.2%wg1 } send hello
09:47:22 route,ospf,packet ospf_v2 { version: 2 router-id: 192.168.50.1 } backbone_v4 { 0.0.0.0 } interface { p2p 192.168.17.2%wg1 } neighbor { router-id: 192.168.50.2 state: Exchange } receive DD from 192.168.17.3 Init Master More sequence 3202
09:47:22 route,ospf,packet ospf_v2 { version: 2 router-id: 192.168.50.1 } backbone_v4 { 0.0.0.0 } interface { p2p 192.168.17.2%wg1 } neighbor { router-id: 192.168.50.2 state: Exchange } send DD to 192.168.17.3 sequence 3202
09:47:25 route,ospf,packet ospf_v2 { version: 2 router-id: 192.168.50.1 } backbone_v4 { 0.0.0.0 } interface { p2p 192.168.17.2%wg1 } neighbor { router-id: 192.168.50.2 state: Exchange } hello
09:47:27 route,ospf,packet ospf_v2 { version: 2 router-id: 192.168.50.1 } backbone_v4 { 0.0.0.0 } interface { p2p 192.168.17.2%wg1 } neighbor { router-id: 192.168.50.2 state: Exchange } receive DD from 192.168.17.3 Init Master More sequence 3202
09:47:27 route,ospf,packet ospf_v2 { version: 2 router-id: 192.168.50.1 } backbone_v4 { 0.0.0.0 } interface { p2p 192.168.17.2%wg1 } neighbor { router-id: 192.168.50.2 state: Exchange } send DD to 192.168.17.3 sequence 3202
09:47:32 route,ospf,packet ospf_v2 { version: 2 router-id: 192.168.50.1 } backbone_v4 { 0.0.0.0 } interface { p2p 192.168.17.2%wg1 } send hello
09:47:32 route,ospf,packet ospf_v2 { version: 2 router-id: 192.168.50.1 } backbone_v4 { 0.0.0.0 } interface { p2p 192.168.17.2%wg1 } neighbor { router-id: 192.168.50.2 state: Exchange } receive DD from 192.168.17.3 Init Master More sequence 3202
09:47:32 route,ospf,packet ospf_v2 { version: 2 router-id: 192.168.50.1 } backbone_v4 { 0.0.0.0 } interface { p2p 192.168.17.2%wg1 } neighbor { router-id: 192.168.50.2 state: Exchange } send DD to 192.168.17.3 sequence 3202
fw1csc2 mikrotik side below
# model = RB5009UG+S+
# serial number = [snip]
add admin-mac=[snip] auto-mac=no comment=defconf name=bridge
add name=lo1 protocol-mode=none
set [ find default-name=ether1 ] comment=WAN
/interface wireguard
add comment=fw1csc1 listen-port=51821 mtu=1420 name=wg1
/interface vlan
add interface=bridge name=vlan2 vlan-id=2
set 7 mirror-egress=yes mirror-ingress=yes mirror-ingress-target=ether3
/interface ethernet switch
set 0 mirror-egress-target=ether3
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=WG_tun
add include=LAN,WG_tun name=NoBlock
add name=dhcp ranges=192.168.10.50-192.168.10.254
add name=dhcp_prod ranges=192.168.11.50-192.168.11.250
add address-pool=dhcp interface=bridge lease-time=23h59m59s name=defconf
add address-pool=dhcp_prod interface=vlan2 lease-time=23h59m59s name=dhcp_prod
/queue type
add kind=fq-codel name=FQ_Codel
/queue interface
set ether1 queue=FQ_Codel
/routing ospf instance
add disabled=no name=ospf_v2
add disabled=yes name=ospf_v3 version=3
/routing ospf area
add disabled=no instance=ospf_v2 name=backbone_v4
add disabled=no instance=ospf_v3 name=backbone_v6
/routing bgp template
set default as=65510 disabled=no output.no-client-to-client-reflection=yes routing-table=main
add as=65010 disabled=no multihop=yes name=peer nexthop-choice=propagate output.keep-sent-attributes=yes .no-client-to-client-reflection=yes routing-table=main templates=\
    default
/certificate settings
set crl-download=yes crl-use=yes
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether2
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether3 pvid=5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 trusted=yes
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether5
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether6 pvid=2
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether7
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
/ip settings
set tcp-syncookies=yes
/ipv6 settings
set accept-router-advertisements=yes
/interface bridge vlan
add bridge=bridge tagged=ether4,ether7 untagged=vlan2 vlan-ids=2
add interface=lo1 list=LAN
add interface=vlan2 list=LAN
add interface=wg1 list=WG_tun
/interface wireguard peers
add allowed-address=0.0.0.0/0 comment=fw1csc1 endpoint-address=fw1csc.[snip] endpoint-port=51820 interface=wg1 persistent-keepalive=25s public-key=\
    "[snip]"
add address=192.168.10.1/24 comment=defconf interface=bridge network=192.168.10.0
add address=192.168.50.1 interface=lo1 network=192.168.50.1
add address=192.168.11.1/24 comment=prod interface=vlan2 network=192.168.11.0
add address=192.168.17.2/31 comment=fw1csc1 interface=wg1 network=192.168.17.2
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
add address=192.168.10.0/24 comment=defconf dns-server=192.168.10.1 domain=[snip] gateway=192.168.10.1 netmask=24
add address=192.168.11.0/24 comment=prod dns-server=192.168.11.1 domain=[snip] gateway=192.168.11.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.10.1 comment=defconf name=router.lan
add action=accept chain=input comment=vpn_local_in in-interface-list=WG_tun
add action=accept chain=input comment="wireguard 1" dst-port=51821 protocol=udp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!NoBlock
add action=accept chain=forward comment="defconf: accept in ipsec policy" disabled=yes ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" disabled=yes ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat comment=dns dst-port=53 in-interface-list=WAN protocol=udp to-addresses=192.168.10.15 to-ports=53
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www-ssl disabled=no
/ip ssh
set host-key-size=4096 strong-crypto=yes
/ipv6 address
add address=::7a9a:18ff:feab:79ae eui-64=yes from-pool=global interface=bridge
add eui-64=yes from-pool=global interface=*E
add address=::874:bff:fed3:e88d eui-64=yes from-pool=global interface=lo1
/ipv6 dhcp-client
add interface=ether1 pool-name=global prefix-hint=::/48 request=address,prefix use-peer-dns=no
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ipv6 nd
add advertise-dns=no hop-limit=64 interface=ether1 ra-preference=low reachable-time=5m
/routing bfd configuration
add disabled=yes interfaces=WG_tun
/routing bgp connection
add as=65010 connect=yes disabled=no listen=yes local.address=192.168.50.1 .role=ebgp-peer multihop=yes name=fw1csc1 nexthop-choice=propagate output.keep-sent-attributes=yes \
    .no-client-to-client-reflection=yes remote.address=192.168.50.3 .as=65030 routing-table=main templates=peer
/routing ospf interface-template
add area=backbone_v4 cost=10 disabled=no interfaces=lo1 passive
add area=backbone_v6 cost=10 disabled=no interfaces=lo1 passive
add area=backbone_v4 cost=50 disabled=no interfaces=WG_tun priority=1 type=ptp use-bfd=no
add area=backbone_v6 cost=50 disabled=no interfaces=WG_tun type=ptp use-bfd=no
/system clock
set time-zone-name=America/Chicago
/system identity
set name=fw1.[snip]
/system logging
add disabled=yes topics=ospf
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes multicast=yes use-local-clock=yes
/system routerboard settings
# Firmware upgraded successfully, please reboot for changes to take effect!
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
/tool romon port
add cost=200 disabled=no forbid=yes interface=ether1
fw1csc1 - er-x side - tried to get the relevant pieces, let me know if I missed something.
firewall {
    broadcast-ping disable
    group {
        port-group Wireguard {
            description ""
            port 51820-51822
    name VPN_IN {
        default-action accept
        rule 10 {
            action accept
            description Estab
            log disable
            protocol all
            state {
                established enable
                invalid disable
                new disable
                related enable
        rule 20 {
            action drop
            description invalid
            log disable
            protocol all
            state {
                established disable
                invalid enable
                new disable
                related disable
        rule 30 {
            action accept
            description http(s)
            destination {
                port 80,443
            log disable
            protocol tcp_udp
            state {
                established disable
                invalid disable
                new enable
                related disable
        rule 40 {
            action accept
            description icmp
            log disable
            protocol icmp
        rule 50 {
            action accept
            description bgp
            destination {
                address 192.168.50.0/24
                port bgp
            log disable
            protocol tcp
            source {
            state {
                established disable
                invalid disable
                new enable
                related disable
        rule 60 {
            action accept
            description ssh
            destination {
                port 22
            log disable
            protocol tcp
            state {
                established disable
                invalid disable
                new enable
                related disable
        rule 61 {
            action accept
            description proxmox
            destination {
                port 8006
            log enable
            protocol tcp_udp
            state {
                established disable
                invalid disable
                new enable
                related disable
    name VPN_LOCAL {
        rule 10 {
            action accept
            description Estab
            log disable
            protocol all
            state {
                established enable
                invalid disable
                new disable
                related enable
        rule 20 {
            action drop
            description invalid
            log disable
            protocol all
            state {
                established disable
                invalid enable
                new disable
                related disable
        rule 30 {
            action accept
            description ospf
            log disable
            protocol ospf
        rule 40 {
            action accept
            description dns
            destination {
                port 53
            log disable
            protocol tcp_udp
        rule 50 {
            action accept
            description bgp
            destination {
                address 192.168.50.1
                port bgp
            log disable
            protocol tcp
            source {
            state {
                established disable
                invalid disable
                new enable
                related disable
        name WAN_LOCAL {
        default-action drop
        description "WAN to router"
        rule 10 {
            action accept
            description "Allow established/related"
            state {
                established enable
                related enable
        rule 20 {
            action accept
            description WireGuard
            destination {
                group {
            log disable
            protocol udp
        rule 21 {
            action accept
            description "backup https"
            destination {
                port 8443
            log enable
            protocol tcp_udp
            state {
                established disable
                invalid disable
                new enable
                related disable
interfaces {
    ethernet eth0 {
        address dhcp
        description Internet
        dhcp-options {
            default-route update
            default-route-distance 210
            name-server no-update
        dhcpv6-pd {
            no-dns
            pd 0 {
                interface switch0 {
                    host-address ::1
                    prefix-id :0
                    service slaac
                interface switch0.2 {
                    host-address ::1
                    prefix-id :1
                    service slaac
                prefix-length /60
            rapid-commit enable
        duplex auto
        firewall {
            in {
                ipv6-name WANv6_IN
                name WAN_IN
            local {
                ipv6-name WANv6_LOCAL
                name WAN_LOCAL
    interface wireguard wg0 {
 address 192.168.17.3/31
 address fe80::250:55ff:fec0/64
 description fw1csc2
 firewall {
     in {
         ipv6-name VPNv6_IN
         name VPN_IN
     local {
         ipv6-name VPNv6_IN
         name VPN_LOCAL
 ip {
     ospf {
         cost 50
         dead-interval 40
         hello-interval 10
         priority 1
         retransmit-interval 5
         transmit-delay 1
 listen-port 51820
 mtu 1420
 peer [snip] {
     allowed-ips 0.0.0.0/0
     allowed-ips ::0/0
     endpoint [snip].sn.mynetname.net:51821
     persistent-keepalive 25
 private-key /config/auth/wg.key
 route-allowed-ips false
    loopback lo {
        address 192.168.50.1/32
protocols {
    ospf {
        area 0.0.0.0 {
            area-type {
                normal
            network 192.168.17.0/24
            network 192.168.50.0/24
            network 192.168.10.0/24
        log-adjacency-changes {
        parameters {
            abr-type cisco
            router-id 192.168.50.1
        passive-interface default
        passive-interface-exclude wg0
Basic diagram Image
nellicus
Re: wireguard /31 with edgerouter ospf failling to establish peer
Sun Jan 21, 2024 4:00 am
I ran into this myself between RouterOS and VyOS. At this time MikroTik RouterOS 7 does not officially support /31 prefixes. SOURCE Though, there are a few hacks to make it work. Older post with details
In short, you set the IP address on your interface as a /32 and the network as the remote IP. You can use the /31 on the remote side if supported. This along with PtP in the OSPF config should form your adjacency. I have this running on a few of the links in my infrastructure, but have moved to /30's where interoperability is needed. Hoping we get /31 support in the future/
/ip/address/add interface=te-1-0-1 address=10.10.10.1/32 network=10.10.10.2/code]
ikiris
Sun Jan 21, 2024 3:33 pm
Oh perfect, thank you. I’ll just renumber the tunnels into 30s.
Users browsing this forum: No registered users and 3 guests
