peterborough
RPKI
Tue Jan 23, 2024 1:16 pm
We have RPKI setup to filter BGP routes received from providers, however they do not seem to be getting filtered.
We have inbound filters setup
rpki-verify RPKI
if (rpki invalid) { reject } else { accept }
under the same chain name as other working inbound filters and are on the latest OS.
to check to see if the router is working and able to connect to the Validator
/routing/rpki> /routing/rpki/ rpki-check group=RPKI prefix=70.132.18.0/24 origin-as=16509
valid
/routing/rpki> /routing/rpki/ rpki-check group=RPKI prefix=2a05:dfc7:1000::/48 origin-as=205531
invalid
mrz
Re: RPKI
Tue Jan 23, 2024 2:46 pm
rpki-verify just adds the RPKI status to the prefix, you can see whether status have been addd by looking at parameters in /routing/route/print detail
To actually reject or accept prefix you have to match the rpki status and add apropriate action, see example here:
https://help.mikrotik.com/docs/display/ROS/RPKI
peterborough
Re: RPKI
Tue Jan 23, 2024 2:56 pm
the issue is, none of the routes are getting marked
peterborough
Re: RPKI
Wed Jan 24, 2024 3:21 pm
rpki-verify RPKI is not working and must be a bug in the firmware. Can someone please check?
erlinden
Re: RPKI
Wed Jan 24, 2024 3:32 pm
https://mikrotik.com/support
peterborough
Re: RPKI
Wed Jan 24, 2024 4:29 pm
I already done this but no response
Network5
Re: RPKI
Thu Jan 25, 2024 11:37 pm
I'm using RPKI since ROS 7.xx. Never had a problem with that. One session is pointing to Routinator and the second one to Fort validator.
add chain=bgp_rpki disabled=no rule="rpki-verify groupFIRT"
add chain=bgp_rpki disabled=no rule="if (rpki invalid) { reject }"
Pay attention to the filtering order: for example you should filter first rfc5735 then RPKI with reject only, then all other filters with accept rules. Avoid using "if else accept" unless in the last filter rule.
In your example you are using "else" in the RPKI validation. This means that all the filter that follows are useless. If you have another "if else accept" before the RPKI validation the RPKI filtering is useless, because the routes are being accepted before the validation.
Users browsing this forum: No registered users and 11 guests
