Code: Select all
/interface wifi channel
add band=2ghz-ax comment="16 db" disabled=no frequency=2462 name=channel11x width=20mhz
add band=5ghz-ax comment="DFS 1 minuto, 30db" disabled=no frequency=5660,5220 name=channel132_46x width=20/40mhz
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes name=secWPA3 wps=disable
/interface wifi configuration
add channel=channel11x country=Spain disabled=no mode=ap name=cfg11x security=secWPA3 ssid=Magalis
add channel=channel132_46x country=Spain disabled=no mode=ap name=cfg134_46x security=secWPA3 ssid=Santi
/interface wifi
set [ find default-name=wifi1 ] comment=5GHz configuration=cfg134_46x configuration.mode=ap .tx-power=19 disabled=no
set [ find default-name=wifi2 ] comment=2.4GHz configuration=cfg11x configuration.mode=ap disabled=no mtu=1500
I only have that log related to wifi1 after the radar signal
I saw this the next day, at no time did he get up according to the logs, How to make it lift at another frequency or at the same one after 1 minute?
