Since Azure VPN defaults to route-based VPN where it uses VTI feature but mikrotic dont support it.
How do you configure site to site VPN connection to onpremise site? Does it require combination of BGP and/or GRE Tunnel?
For instance:
Local Range: 192.168.88.0/24
Azure Range: 10.0.0.0/23
Can you also recommend the best setup ? For instance, when creating a connection, there is an option to define custom "IPsec/ IKE policy" and/or use Policy based traffic selector.
Thanks,
Mark
