FingerlessGloves
Rest API - Logout
Fri Feb 02, 2024 1:49 am
I've made a few python scripts to gather monitoring data and also to manage some WireGuard tunnels.
Every time the scripts connect, it creates a "Active User" entry, and as the scripts run quite often I have a massive list of Active Users, which are not actually active any more. Is there a way I can do a log out after I've finished interacting with the REST API to clear down the "Active User" list, as if this runs for weeks, the list looks like it'll become a mile long, as it's not cleared any since it last rebooted. I've looked at the documentation and I see no mention of doing a logout, but surely there's a way to clear this list down 😅
Below are screenshots some of these connections in the list, and they've been there for over 24 hours now.
merkkg
Re: Rest API - Logout
Sat Feb 24, 2024 12:51 pm
Did you ever find a solution to this, I have this issue as well. my active users is over 1,500 now
miku
Tue Mar 05, 2024 12:54 am
You can find solution in viewtopic.php?p=977598#p977598
Users browsing this forum: No registered users and 7 guests
