Unless I am reading the wireless specification table wrong: the AX2 achieves the same receive-sensitivity with less transmit power. Isn't that better?hAP ax3 should have better antennas and better coverage. By looking at those reports, it seems that either a few users have not properly attached their external antennas, or there might be some hardware defect. I suggest to email support if you have a unit that performs worse than ax2
Well, that should not be true and when you discover a case like that you should report it as a bug.It is not difficult, but it takes some time, and some attention, the biggest issue is AFAIK, even with relatively simple configurations that the lines need to be pasted/inserted in the new configuration with a logic order (which is not necessarily the order of the lines in the export) otherwise they will be rejected because (example) you are changing a setting on something (like an interface or routing table) that has not yet been created on the new device.
Security is important, but it is not entirely unlike when you loose your house keys.Another advantage of Backup is that the file is AES encrypted with a password of your choosing. This means that if you lose control of it (e.g. it's on a USB stick that you leave somewhere by mistake), there's an almost zero risk that someone can work out your configuration. An .rsc file created with "show-sensitive" is just a text file and will contain ISP and wireless passwords. So you need to be more careful protecting it.
Yes, but only when you remove existing chains before you copy/paste the new ones!Thank yoU!!
having this file ios awesome I can copy this into a new router piecewise as I wish!!!!! even the firewall chains!!!!
This can work if you go through the script very carefully and double-check. The key things I've found to watch out for are static IP address assignments and MAC addresses. But I only trust a script on an identical model. I also wouldn't entirely trust a script from an older version of ROS with an up to date version. So yes, lots of caveats. IMO it's better to maintain a detailed configuration guide in Excel, LibreCalc or Google Sheets. This is for my home/experimental hAP ax2:You cannot "really" copy configuration between devices, not even the same exact make/model.
Interesting you should mention this because I've been doing a LOT of experimentation and research in this area. I must be bored. It was triggered by me demoting my Virgin Media Superhub to a modem and using a hAP ax2 as my main router/firewall/access point for a small house but with very thick stone walls.only point to mention when you get about 5/10 meters from the device the signal strength already drops.
thanks for this heads up will do next time!A good fix is to not reboot routers unless it is required to upgrade software or install an additional package. MikroTik routers do not need to be rebooted after a config change or after some uptime.
Next time you face the same situation anyway, instead of reboot the PC try to unplug the network cable for a few seconds.
Nothing, but sometimes it is easier to just click a couple of buttons.What's wrong with good'ol command line and ipconfig /renew ?
This isn't limited to Mikrotik - Ubquiti was in the same boat with older Unifi devices. Passive PoE was introduced to reduce complexity and therefore cost. That cost saving might not stack up these days.active 802.3af or at or passive
Noone said that it was exclusively Mikrotik, as a matter of fact the passive, low voltage, approach - when suitable - is (IMHO) easier to deal with than having to fight against the different implementations of 802.3af and at by different vendors.This isn't limited to Mikrotik - Ubquiti was in the same boat with older Unifi devices. Passive PoE was introduced to reduce complexity and therefore cost. That cost saving might not stack up these days.active 802.3af or at or passive
When it works, it works, when it doesn't it doesn't.I never had to fight against 802.3AF/AT implementations! It always "just works".
But of course it requires way more hardware than "passive PoE".
Isn't that always the case I had a very weird problem with a CSS106-1G-4P-1S (SwOS) recently. It was supplying PoE to a UISP Nanostation Loco 5AC, part of a short P2P bridge. It had worked flawlessly for several years until about two weeks ago when the access point end (hard wired to RB40111 router via that switch) started dropping packets randomly. EMCO Ping Monitor showed fine for 10 minutes then big packet loss. It's currently bypassing the CSS106 and is working fine. But it took me hours to pin it down to the switch as, you know, switches just work Lesson learnt! I digress..When it works, it works, when it doesn't it doesn't.
In my case I use HP or Aruba switches and I use them to power all kinds of devices (telephones, APs of different make including MikroTik) and IRecent example:
viewtopic.php?t=202381
did some more testing in the room behind where the AX2 is sitting seemed to get full signal on both 2GHZ and 5 GHZright now 2 GHZ is pushing about 150 MB 5 GHZ is pushing 350 MBTo sum it up:
2.4 GHz sucks (because it is slow and - in densely populated areas - polluted by countless conflicting radios).
5 GHz sucks even more because it won't go through walls (or any other thing thicker than a sheet of paper) and let's not forget the real or fake radar interferences, 10 minutes cac's, etc., so it will work (fast enough) or not work.
A candle (in the wind) vs. a blinking light, compare with the light of the sun (a good ethernet cabled connection).
Since you are Italian, "Se sei bello ti tirano le pietre, se sei brutto ti tirano le pletre". (for non-italian readers, this was an old song, translatable to "they throw stones at you, no matter if you are ugly or beautiful").
This depends upon your definition of slow. Many UK consumers are still on fibre-to-the-cabinet where the maximum you'll ever get is 80Mbps. My hAP ax2 with Wi-Fi 6 devices can get ~120Mbps which isn't bad. Office use is a different beast though.2.4 GHz sucks (because it is slow and - in densely populated areas - polluted by countless conflicting radios).
Good catch400 millibit/s is quite easy to achieve, even with smoke signals.
I see many semi-casual users that have 2500 in download and that are complaining "my GB ethernet is so slow!!"I see your many UK users and.raise with many italian users that get with FTTC "target" 30 MB, actual 20-25MB.
Meanwhile, in many cities there is available FTTH with 300/500/1000 guaranteed bandwidth (in download).
and:Please, stop calling megabits as MB.
MB = megabytes
Mb = megabits
or millibarns though more commonly inverse squared gigaelectronvolts are used:and:
mb = millibits
I've just got 160Mbps (ducks in case I've got the suffix wrong) on 2.4GHz sat right in front of my hAP ax2. Pretty impressive as the 2.4GHz channel is pretty congested here. I need to read up on the Wi-Fi 6 voodoo magic some more as it how to manages to get such high speeds compared to Wi-Fi 4. It's clearly making more effective use of the same bandwidth.anyhow devices in the same room as the AX2 its pushing more than 200 MB on 2 GHZ and more than 700 MB on the 5 GHZ
excuuuuuseee meeePlease, stop calling megabits as MB.
MB = megabytes
Mb = megabits
Although it works, it's not the recommended way.
then what I did was I created a Bridge and included eth5 & VLAN and set up the DHCP server on the bridge and Lo and behold the thingy assigned an IP to my PC
is this right?
thanks!!VLAN handling over 1 bridge.
Should always work, regardless of device type.
For some devices it is possible performance gains can be obtained doing things slightly different (see relevant pages for that in Help).
But the generic VLAN handling using 1 bridge will always work.
Not sure that's not an oxymoronthis is probably the most logical way to work with VLANS!!!
