fezo
guest wifi capsman v2 bridge
Sat Feb 03, 2024 3:19 pm
Hello. I can't find a solution. I hope there is someone knowledgeable here who can help. I have a capsman v2 network. There is guest wifi in another bridge. unfortunately, if I connect to the cap, I still get the same IP as the capsman gives me. if I connect to the guest wifi on the capsman device, it gives the ip address used by the guest bridge
erlinden
Re: guest wifi capsman v2 bridge
Sat Feb 03, 2024 10:47 pm
Instead of using multiple bridges, you can also (better) use VLAN. It will make your life so much easier!
If you want to solve it with the current config, please share it:
/export file=anynameyoulike
Remove serial and any other private info and post in between code tags by using the </> button.
fezo
Sun Feb 04, 2024 8:35 am
hi, thanks for the reply. Does this mean that the guest bridge does not work with the cap? Should I always use VLAN?
erlinden
Sun Feb 04, 2024 11:38 am
I am pretty sure that is the case.
Users browsing this forum: pepe262 and 11 guests
