goodbye
Intel WiFi with WPA3-Personal & GCMP (Solved)
Mon Feb 05, 2024 10:26 pm
Hi!
Just wanted to check... has anyone else noticed problems getting Windows devices with Intel NICs working with WPA3 & GCMP 256?
Intel's product brief for the NICs indicate that they are compatible with WPA3, 128-bit CCMP, and 256-bit GCMP. However, only 128-bit CCMP seems to actually work.
The Android devices I have to test with (Pixel 7 Pros) work with literally any valid configuration of WPA3-Personal.
CAPs: Audience
RouterOS: 7.13.3 w/ wifi-qcom-ac package
Thanks for any insight!
nonolk
Re: Intel WiFi with WPA3-Personal & GCMP
Tue Feb 06, 2024 10:55 am
Hello @goodbye,
Yes it's a known behaviour, see here https://help.mikrotik.com/docs/display/ ... Properties, look at encryption part, there is a special remark for intel cards.
Best regards,
ToTheFull
Tue Feb 06, 2024 11:41 am
Try this at a windows command prompt it should show you.
netsh wlan show drivers
goodbye
Wed Feb 07, 2024 1:39 am
Hello @goodbye,
Best regards,
Thanks!
But this chip with the latest drivers (or, really, drivers from last year) should support both gcmp-256. And yet...
goodbye
Wed Feb 07, 2024 1:48 am
That's actually gives a lot of insight, and definitely shows Intel's shenanigans.
WPA3-Personal(SAE) and OWE only support CCMP
WPA3-Enterprise only supports GCMP-256
That's... wow.
Thanks for pointing this out!
C:\WINDOWS\system32>netsh wlan show drivers
Interface name: Wi-Fi
    Driver                    : Intel(R) Wi-Fi 6 AX201 160MHz
    Vendor                    : Intel Corporation
    Provider                  : Intel
    Date                      : 29-Nov-23
    Version                   : 23.20.0.4
    INF file                  : oem197.inf
    Type                      : Native Wi-Fi Driver
    Radio types supported     : 802.11g 802.11a 802.11ac
    FIPS 140-2 mode supported : Yes
    802.11w Management Frame Protection supported : Yes
    Hosted network supported  : No
    Authentication and cipher supported in infrastructure mode:
                                Open            None
                                Open            WEP-40bit
                                Open            WEP-104bit
                                Open            WEP
                                WPA-Enterprise  TKIP
                                WPA-Enterprise  CCMP
                                WPA-Personal    TKIP
                                WPA-Personal    CCMP
                                WPA2-Enterprise TKIP
                                WPA2-Enterprise CCMP
                                WPA2-Personal   TKIP
                                WPA2-Personal   CCMP
                                Open            Vendor defined
                                WPA3-Personal   CCMP
                                Vendor defined  Vendor defined
                                WPA3-Enterprise GCMP-256
                                OWE             CCMP
    IHV service present       : Yes
    IHV adapter OUI           : [00 00 00], type: [00]
    IHV extensibility DLL path: C:\WINDOWS\system32\IntelIHVRouter10.dll
    IHV UI extensibility ClSID: {00000000-0000-0000-0000-000000000000}
    IHV diagnostics CLSID     : {00000000-0000-0000-0000-000000000000}
    Wireless Display Supported: Yes (Graphics Driver: Yes, Wi-Fi Driver: Yes)
Users browsing this forum: DanMos79 and 5 guests
