sas2k
spare part exact name\code? wifi Antenna for HAP AC3 ?
Fri Feb 09, 2024 12:32 pm
Dear Friends !
I've broken down wifi (2.4+5) antenna on hap ac3.
What is spare part exact name\code ?
"MikroTik HGO-ANTENNA-OUT" looks like what I need.
Is it proper antenna ?
https://mikrotik.com/product/hgo_antenna_out
Thank you !
holvoetn
Re: spare part exact name\code? wifi Antenna for HAP AC3 ?
Fri Feb 09, 2024 12:51 pm
Yes.
That should be the one.
bpwl
Fri Feb 09, 2024 2:10 pm
This is the "outdoor" version. (No hinge!)
If not available, Check web-shops for "dual band rubber duck antenna" ... check the connector type, impedances are mostly 50 Ohm. Gain varies from 2dBi to 8 dBi.
Have to try some one day ... many results for my search string "Omnidirectional+WiFi+Antenna+8dBi+RP-SMA+Male+2.4GHz+5GHz+5.8GHz+Dual+Band". Try at your own risk!
holvoetn
Fri Feb 09, 2024 2:13 pm
Good catch ! Didn't see that.
normis
Fri Feb 09, 2024 2:46 pm
Yes, that outdoor antenna is not flexible, it is a one piece. You can't buy the hAP ax3 antenna separately from MikroTik, but you could use a different brand antenna if it has the same connector type and is compatible with the desired frequency
Users browsing this forum: No registered users and 2 guests
