frank333
Drop invalid FW forward
Fri Feb 09, 2024 1:52 pm
I keep getting these kinds of alerts, how can I fix it?
firewall.rsc
baragoon
Re: Drop invalid FW forward
Fri Feb 09, 2024 1:56 pm
disable logging for this firewall rule
frank333
Fri Feb 09, 2024 2:05 pm
:D ok , but if they are reported it means that something is not working in the firewall . what could it be.
baragoon
Fri Feb 09, 2024 2:22 pm
it's reported because logging for drop rule is enabled
if you disable logging this rule will continue drop but will stop spamming your log
frank333
Fri Feb 09, 2024 2:49 pm
OK, but the forward traffic is the traffic generated between the two interfaces, so I think something in my internal network is trying to open a port on the router to communicate directly to the outside and is being blocked.
erlinden
Fri Feb 09, 2024 2:51 pm
Interestingly...there is no drop filter rule on the forward chain that logs...
Port 80 and 443 seems to be standard web browsing?
frank333
Fri Feb 09, 2024 3:09 pm
@erlinden ,
The rule set seems complete to me, what should I enter?
Mesquite
Fri Feb 09, 2024 3:44 pm
nm.....
Mesquite
Fri Feb 09, 2024 3:47 pm
My advice is to get rid of all your RAW chain rules for starters.
Also get rid of the mangle ttl rule, its just too weird at least while troubleshooting your issue.
Modify the input chain and forward chain like so: This is the same as your current rules in that we allow LAN to WAN traffic and then drop everything else.
In between we use a rule to capture any issues. Enable it view the logs, and then disable it as one doesnt need to log all the crap all the tieme
add action=accept chain=input in-interface-list=LAN comment="Allow LAN to router services"
add action=reject chain=input in-interface-list=LAN reject-with=icmp-admin-prohibited log=yes log-prefix="bad apples" {optional --> useful but only if interested in tracking LAN issues }
add action=drop chain=input comment="drop all else"
add action=accept chain=forward comment="allow internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="port forwarding" connection-nat-state=dstnat { disable if not required }
add action=reject chain=forward in-interface-list=LAN reject-with=icmp-admin-prohibited log=yes log-prefix="bad apples" { optional -->useful for tracking LAN issues}
add action=drop chain=forward comment="drop all else"
frank333
Fri Feb 09, 2024 4:41 pm
ok tonight I will try , and then I will report back if I still have problems .
mkx
Fri Feb 09, 2024 5:17 pm
A comment on logged items: when either client or server decides to finish TCP connection, it'll send a packet with flags ACK and FIN to the other party. The other party will respond with FIN ACK as well. And any of parties might re-send FIN ACK (to make sure that the other party "gets it").
Now, stateful firewall tracks these flags and as soon as it deems connection finished (seeing FIN from both ends) it marks the connection as closed (in its connection tracking table) and removes it from the table shortly after. As soon as connection is purged from connection tracking table, any packet belonging to the dying connection is deemed invalid ... and dropped if appropriate rule exists. And that's what you're seeing. Hence the recommendation to not log those drops as they are benign.
pe1chl
Fri Feb 09, 2024 5:38 pm
It is a known problem in Linux connection tracking that has been there for years but is never fixed.
As recommended, do not log invalid packets. Or make another rule above that which drops invalid packets with TCP protocol and TCP flag FIN or RST, does not log these, and then keep this rule with logging.
frank333
Fri Feb 09, 2024 7:22 pm
ok now everything is clearer to me. thanks @mkx and @pe1chi
frank333
Sat Feb 10, 2024 2:31 pm
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="drop forward TCP fin rst" \
    connection-state=invalid protocol=tcp tcp-flags=fin,rst
    connection-state=invalid log=yes log-prefix="drop invalid FW"
P.S. How do you move the position of a firewall rule with Webfig? I had to use winbox.
pe1chl
Sat Feb 10, 2024 3:44 pm
Just drag the line up or down using the mouse...
frank333
Sun Feb 11, 2024 9:28 am
:) to me ,it no longer works using firefox ,chromium and ROS 7.12.1
Users browsing this forum: Ahrefs [Bot], PBondurant, webnoob and 21 guests
