Sit75
mAP Lite - refresh
Fri Feb 09, 2024 9:22 pm
Is there any chance for mAP refresh supporting 5GHz, 802.1af/at and 1 Gig interface? It would be nice.
holvoetn
Re: mAP Lite - refresh
Sun Feb 11, 2024 5:22 pm
Not as small as map but maybe close enough ?
Add your own case and presto.
L11ug
https://mikrotik.com/product/l11ug_5haxd
Cha0s
Tue Feb 13, 2024 9:46 pm
Compared to mAP Lite, L11UG is gigantic.
L11UG is 105mm x 105mm, while mAP Lite is 48mm-ish x 48mm-ish.
You can fit 4 mAP Lites in the footprint of one L11UG :shock:
holvoetn
Tue Feb 13, 2024 10:06 pm
I doubt you can get 5GHz AX in size of map.
Users browsing this forum: grusu and 7 guests
