LAN is back in operation, clients have internet access.
However the issue I am facing now is: none of the clients (smart phones) connected to the CapAx, can connect to the internet.
Also I get this strange message, where IP .171 is the CapAX and .43 is my admin PC.
Code: Select all
ether1: bridge RX looped packet - MAC 48:a9:8a:e4:fe:bd -> 90:1b:0e:aa:b2:92 ETHERTYPE 0x0800 IP TCP 192.168.178.171:8291 -> 192.168.178.43:51809
If I did change something after my latest backup I do at least not remember .
No idea if/what I messed up.
Running out of ideas, need a break, hoping for help.
Thanks a lot !
Code: Select all
# 2024-02-10 18:43:34 by RouterOS 7.13.2
# software id = XGEA-TLYF
# model = cAPGi-5HaxD2HaxD
# serial number = redacted
add admin-mac=48:A9:8A:E4:FE:BD auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .frequency=5560 \
.skip-dfs-channels=10min-cac .width=20/40/80mhz configuration.country=\
Germany .mode=ap .ssid=DarkStar disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk .connect-priority=0 .ft=\
yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .frequency=2437 \
.skip-dfs-channels=disabled .width=20/40mhz configuration.country=Germany \
.mode=ap .ssid=DarkStar disabled=no security.authentication-types=\
wpa2-psk,wpa3-psk .connect-priority=0 .ft=yes .ft-over-ds=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add bridge=bridge interface=ether1
add comment=defconf interface=ether1 list=LAN
/interface wifi access-list
add action=accept disabled=no mac-address=30:58:90:75:2C:5C
192.168.88.0
/ip dhcp-client
add comment=defconf interface=bridge
set allow-remote-requests=yes
/ipv6 firewall address-list
/system clock
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set broadcast=yes enabled=yes manycast=yes
/system ntp client servers
add address=192.168.178.55
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
/tool mac-server
/tool mac-server mac-winbox
