7.14rc1 on rb750
about 6k address-list entries
/ip firewall address-list add works reasonably fast. It responds even faster if such entry is already present.
Yet /ip firewall address-list print where address=... is slow as hell. 11 seconds at best.
Same goes for /ip firewall address-list remove [ find address= ] - also about 11 seconds.
Does that sound like fine enough behavior or are there plans to speed it up a bit?
PS. whats up with syntax inconsistencies like
versus
Neither /ip firewall address-list print [ find address= ] or /ip firewall address-list remove where address= work. Why do you insist using different syntax for essentially the same thing?
rgds,
vv
