Hello everyone,
I'm trying to test this product for a project but I'm having trouble getting the ppp link to work in conjunction with the GPS; I read the documentation online but it doesn't seem to work properly.
The product that just arrived had firmware 7.6 from the factory and the available ports were modbus, modem and usb2 but the ppp connection did not work; after the update to 7.12.1 the new ports available were only modbus and modem, the usb2 port gave an error and was no longer available but the connection doesn't work here either.
I attach two screens, one of the configuration reset after the upgrade to 7.12.1 and the other after changing the APN with the correct one; in both cases the connection does not work even if in the first case it adds an IP address between the routes.
I've tried everything, the sim works correctly on other devices but not here
How can I solve it?
Thank you.
