Hi all,
Please, I need your help to resolve my problem.
I configured a 2nd Subnet for Port 5, but it doesn't obtain IP address of a client pc.
Port 5: 2nd subnet configuration
Address List:
Address: 192.168.99.1/24
Network: 192.168.99.0
Interface: ether5
Others configured below:
DHCP Server
IP Pool
Route List
PS:
Why port5 not blinking or no green light in the router? Also, it showing italic in Address list? DHCP server red italic, Route list unreachable.
Do I miss configuration? Btw, I turned off PoE Out under Interface List.
RouterBOARD
Model: 951Ui-2HnD
Current Firmware: 6.49.6
Code: Select all
# feb/12/2024 07:18:59 by RouterOS 6.49.6
# model = 951Ui-2HnD
set [ find default-name=ether1 ] mac-address=x:x:x:x:x:x name=\
ether1-gateway
set [ find default-name=ether5 ] mac-address=x:x:x:x:x:x name=\
ether5-slave-local poe-out=off
/interface l2tp-client
/interface pptp-client
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=\
ICC-Guest supplicant-identity=""
/interface wireless
add authoritative=after-2sec-delay interface=ether1-gateway lease-time=3d \
name=dhcp1
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add comment=Local-DHCP-Jotun name=Pool-Jotun ranges=\
192.168.99.20-192.168.99.250
add address-pool=Pool-Jotun authoritative=after-2sec-delay interface=ap-guest \
name=dhcp2
add address-pool=Pool-Jotun disabled=no interface=ether5-slave-local \
lease-time=3d name=server-ether5-jotun
/interface sstp-client
/queue type
add kind=pcq name="MaximumDownloadSpeed " pcq-classifier=src-address \
pcq-rate=500k
add kind=pcq name="MaximumUploadSpeed " pcq-classifier=dst-address pcq-rate=\
500k
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
set discover-interface-list=discover
add interface=ether5-slave-local list=mac-winbox
/ip accounting
set account-local-traffic=yes enabled=yes
/ip accounting web-access
set accessible-via-web=yes address=192.168.0.99/32
add address=192.168.99.1/24 comment=Jotun-Port5 interface=ether5-slave-local \
network=192.168.99.0
add address=192.168.99.1/24 comment=Jotun-Bridge disabled=yes interface=\
bridge-local network=192.168.99.0
/ip dhcp-client
add address=192.168.99.0/24 comment=ether5-Jotun dns-server=\
192.168.99.1,8.8.8.8 gateway=192.168.99.1
set allow-remote-requests=yes servers=\
1.2.3.4,1.2.3.4,8.8.8.8,1.2.3.4
/ip dns static
/ip firewall address-list
add action=drop chain=forward comment="List of Blocked IP Address" disabled=\
yes dst-port=80,443 protocol=tcp src-address=192.168.0.9
add action=drop chain=input disabled=yes protocol=tcp src-address=192.168.0.9
add action=accept chain=forward comment="Allowed Block Website Here!!!" \
disabled=yes dst-address-list=Youtube src-address-list=\
"Youtube Allowed Users"
add action=add-dst-to-address-list address-list=Youtube address-list-timeout=\
4w2d chain=forward comment="Block Website Here!!!" disabled=yes dst-port=\
443 protocol=tcp src-address=192.168.0.0/24 tls-host=*youtube*
add action=add-dst-to-address-list address-list=Spotify address-list-timeout=\
4w2d chain=forward disabled=yes dst-port=443 protocol=tcp src-address=\
add action=drop chain=forward disabled=yes dst-address-list=Youtube
add action=drop chain=forward disabled=yes dst-address-list=Spotify
/ip firewall mangle
add action=masquerade chain=srcnat comment=JOTUN disabled=yes dst-address=\
192.168.99.0/24
/ip proxy
/ip service
/port remote-access
add
/system clock
set time-zone-autodetect=no time-zone-name=Africa/Luanda
/system identity
/system leds
set 5 interface=ether5-slave-local leds=led5 type=interface-activity
