Hi, I have a HEX router that send Vlan 100 + Untag traffic to a PowerBox Pro in Bridge mode on Eth1. I want Vlan to be Untag on Eth3.
How to configure the PowerBox Pro to do So?
Thx!!!
I'm sending vlan 100 and other untag traffic to powerBox on Eth1. Here is the config from HEX router sending packets:You are only sending 1 VLAN to this powerbox ? Why is your trunk port in WAN list on device you are using as a switch ?
Can you show config from your device that is used as a router ?
