I'm sure I'm just dense, which is the reason I need to ask. I'm trying to configure some route filters for BGP, specifically the output chain. I got a BGP session up between my two routers, and they are advertising routes between the two of them. I want to put some filters in place that make sure only the routes I want are advertised on the output... However, once I select my output filter, my second router no longer sees the routes from the first router. What am I doing wrong?
I've tried a couple different things, and they both have the same results:
Code: Select all
/routing filter rule
add chain=bgp-out comment="Management Network" disabled=no rule="if ( dst==172.16.0.0/22) { accept }"
