alejosne
Ultimate multi-cAP AX configuration
Tue Feb 20, 2024 11:22 am
I know that there is already a lot of content about how to properly configure wifi APs in this forum, but still, I am experiencing multiple issues in my setup and am still struggling to configure them.
I have 1000 square meter space with 4 cAP ax (one in each corner).
I don't use CAPsMAN as I have experiences issues in the past with broadcasting, and it makes my network more complicated (I have a lot of different networking hardware between the router and the APs and CAPsMAN makes it seem like the APs are plugged directly on the router.).
Finally, my APs have two SSIDs: a guest and a main, on two different VLANs.
My problems are the following:
- A lot of devices connect to the 2ghz network, even though there is the 5ghz network with the same SSID next to it.
- Even though I am next to an AP, my computer tends to stay connected to an AP very far away.
- Apple users are experiencing connectivity issues (cannot connect to wifi).
- It is takes some time connecting to the wifi
What I have tried so far:
- Reducing the TX-Power of the 2ghz antenna
- Enabling FT & FT Over DS
- Switching from 20Mhz to 20/40MHz Ce on the 5Ghz antenna
- Disabling WPA3-PSK (leaving only WPA2-PSK)
Here is an export
add name=bridge1 port-cost-mode=short vlan-filtering=yes
/interface vlan
add interface=bridge1 name=vlan30 vlan-id=30
add interface=bridge1 name=vlan40 vlan-id=40
add interface=bridge1 name=vlan99 vlan-id=99
/interface wifi channel
add band=2ghz-ax disabled=no frequency=2412 name=2ghz width=20mhz
add band=5ghz-ax disabled=no name=5ghz width=20/40mhz-Ce
/interface wifi security
add authentication-types=wpa2-psk disabled=no name=Main
add authentication-types=wpa2-psk disabled=no name=Guest
/interface wifi configuration
add country=France disabled=no mode=ap name=Guest security=Guest ssid=Guest
add country=France disabled=no mode=ap name=Main security=Main ssid=Wifi-Prive
/interface wifi
set [ find default-name=wifi2 ] channel=2ghz configuration=Main configuration.mode=ap .tx-power=5 disabled=no name="Main 2ghz" security=Main
set [ find default-name=wifi1 ] channel=5ghz channel.skip-dfs-channels=all configuration=Main configuration.mode=ap disabled=no name="Main 5ghz" security=Main
add configuration=Guest configuration.mode=ap disabled=no mac-address=7A:9A:18:C9:6C:72 master-interface="Main 2ghz" name="Guest 2ghz" security=Guest
add configuration=Guest configuration.mode=ap disabled=no mac-address=7A:9A:18:C9:6C:71 master-interface="Main 5ghz" name="Guest 5ghz" security=Guest
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether1 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface="Main 5ghz" internal-path-cost=10 path-cost=10 pvid=30
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface="Main 2ghz" internal-path-cost=10 path-cost=10 pvid=30
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface="Guest 5ghz" internal-path-cost=10 path-cost=10 pvid=40
add bridge=bridge1 interface="Guest 2ghz" pvid=40
/interface bridge vlan
add bridge=bridge1 tagged=ether1 vlan-ids=30
add bridge=bridge1 tagged=ether1 vlan-ids=40
add bridge=bridge1 tagged=bridge1,ether1 vlan-ids=99
/ip dhcp-client
add interface=vlan99
/system identity
set name=AP-Prod
Thank you for your help,
Arnaud
ips
Re: Ultimate multi-cAP AX configuration  [SOLVED]
Tue Feb 20, 2024 11:36 pm
AFAIK, FT requires CAPsMAN.
I am not sure that FT is needed to make everything work, but I would suggest to try CAPsMAN. Having a single manager could help roaming even if FT is not enabled (unfortunately, it depends on the client).
alibloke
Tue Feb 20, 2024 11:59 pm
Local forwarding could be used with capsman v2, now it's default for wifi-qcom so this won't be the case.
Ca6ko
Long time Member
Long time Member
Wed Feb 21, 2024 12:58 pm
In my opinion 4 points for such an area is not enough.
I have an object where, for example, 450 square meters, two floors, 5 points are not enough.
Did you do a radio survey?
Did you calculate the placement of points, frequency planning?
For your purposes, you need to set up a Capsman.
You need to learn how to do it or hire a specialist.
If there will be specific questions ask us, we will help you.
alejosne
Wed Feb 21, 2024 1:15 pm
Thank you guys for your help.
I did manage to reach more stability with CAPsMAN & FT activated on it.
Honestly, the 4 APs are doing ok, everyone receives wifi properly.
Even though it is 1000 square meters, the walls are pretty thin and the office is a perfect square.
Here is where I am:
- CAPsMAN is working fine (and the packets are forwarded locally, even though I did not find the setting)
- FT is activated and works (I see some devices roaming on the log)
- WPA2 & WPA3 are activated and the apple users are receiving wifi properly.
I still do however have a lot of devices connecting to 2Ghz instead of 5Ghz, but well it is not such an issue.
alibloke
Wed Feb 21, 2024 1:23 pm
Mikrotik support mentioned somewhere on the forum that band steering prioritises 5GHz over 2.4, so the problem is likely a client issue.
jaclaz
Long time Member
Long time Member
Wed Feb 21, 2024 2:17 pm
1000 m2 in a "perfect" square mean roughly 32 meter side, as 32x32=1024
With four devices in the four corners, the most distant point is the center/crossing of diagonals, i.e. 16x1.414=22.62 m
It is not in itself a "crazy" distance IMHO (of course it depends a lot on how internal walls are made, but if they are thin, not particularly opaque to radio waves they shouldn't be such a problem, particularly at 2.4 GHz), surely the 4 AP's in the 4 corners are not the best possible distribution.
I suspect that it is the different (better) "penetration" of 2.4GHz when compared to the 5GHz that makes some devices "prefer" 2.4 GHz.
holvoetn
Wed Feb 21, 2024 2:39 pm
Ideally those devices should be placed in the center of 4 squares making up that 1000m2 area.
So distances will even be less.
11.3m max.
Users browsing this forum: No registered users and 3 guests
