tberg
Router with wireless and voltage monitor
Tue Feb 20, 2024 10:13 pm
I was hoping to have 1 device that could be a home router as well as monitor voltage from a battery backup source. So I'm looking for a lower cost router that has Wi-Fi and has voltage monitoring. So far I've found the hAP lite, ac2, ac3, ax2 and L009 do not have voltage monitor unless I missed it. The other 2 options are hAP AC or Audience. Do they have voltage monitor? If not I will probably have to use 2 devices. The lowest cost Mikrotik I know of with voltage monitor is the hEX.
jaclaz
Long time Member
Long time Member
Re: Router with wireless and voltage monitor
Wed Feb 21, 2024 2:12 am
The map, should have It:
https://mikrotik.com/product/RBmAP2nD
it is definitely cheap and also has wifi, the doubt may be about its capabilities as router and if two ethernet ports are enough.
The hap AC has voltage monitor alright:
https://mikrotik.com/product/RB962UiGS-5HacT2HnT
tberg
Thu Feb 22, 2024 4:17 am
Thanks jaclaz! I didn't think about the mAP. Yes, it will work as a monitor. Ordering a hAP AC to test.
Users browsing this forum: No registered users and 5 guests
