Hi everybody,
Thought I post my question here.
I would like to use hAP ax3 and I would like to be able to control it remotely in our system. We are using custom made boards with STM32 (STM32H753ZIT6) that has CAN interface / ethernet port / SPI / serial port on the board. The ethernet port will be connected to the routers port because we want to use this router as a bridge between the CAN and the Ethernet.
What do you think is the best way to control and configure this router remotely and automatically from a custom made configuration file - network / serial port ?
I am an old school so it kinda feels like serial port is the easiest and safest way to have control over it, but I cannot find more information about the serial port pinout on the board nor cannot find any information this can be used to control and configure the router.
I believe for the most part we at least need to be able to control the Wifi On/Off.
Thank You in advance for you opinions.
