It would be wise if you at least read and understand the information which is been given to you.
The way you are acting here is a huge disrespect to those trying to help you.
E.g. the link erlinden showed you earlier in post #7:
https://help.mikrotik.com/docs/display/ ... ionexample:
You have
NOTHING related to wave2 capsman configured. And you wonder why it does not work ?
I will quote you the relevant part, adjust as needed.
And have a nice rest of your life.
I'm outta here.
#create a security profile
/interface wifi security
add authentication-types=wpa3-psk name=sec1 passphrase=HaveAg00dDay
#create configuraiton profiles to use for provisioning
/interface wifi configuration
add country=Latvia name=5ghz security=sec1 ssid=CAPsMAN_5
add name=2ghz security=sec1 ssid=CAPsMAN2
add country=Latvia name=5ghz_v security=sec1 ssid=CAPsMAN5_v
#configure provisioning rules, configure band matching as needed
/interface wifi provisioning
add action=create-dynamic-enabled master-configuration=5ghz slave-configurations=5ghz_v supported-bands=\
5ghz-n
add action=create-dynamic-enabled master-configuration=2ghz supported-bands=2ghz-n
#enable CAPsMAN service
/interface wifi capsman
set ca-certificate=auto enabled=yes
