genPSI
discarding BFD packet: too short
Sun Feb 25, 2024 2:27 pm
hello gurus !
After update CCR1036v2 from 6.49.8 to 6.49.13 became to got more often spontanously in logs text : discarding BFD packet: too short and Internet became strange works after Mikrotik for some time . And second strange text is Error sending e-mail <autosupout.rif>: AUTH failed , but I dont use any email sending.
For now I blocked 3784 UDP , but not sure 100% if this solution will work.
Tried to change in Routing/BFD - interface all to not usable Bridge2 , but i can not change this .
Any solution of this bug that works ?
genPSI
Re: discarding BFD packet: too short
Wed Mar 13, 2024 10:33 am
This forum are totally dead or support only for VIPs subscribers ?
mrz
Wed Mar 13, 2024 10:40 am
It is not a bug. Something is sending non bfd packet to bfd port, so bfd reports that it is not a valid bfd packet.
BartoszP
Wed Mar 13, 2024 11:16 am
No ... it's the forum used and moderated mostly by same kind of users as You.
We have or we do not have enough time and/or knowledge to answer any kind of a question in a time that can satisfy all.
You always can send your problem to the official support and rise a ticket.
genPSI
Wed Mar 13, 2024 12:21 pm
thanks for finally answer !
I know English and I understand it. But need a workable solution how to fix the problem or solution is just ignore reports in logs and all will be fine ?
For now in logs it is gone again...but can be spontaneously .
genPSI
Wed Mar 13, 2024 12:24 pm
ohhh... i saw here many gurus from Mikrotik , so thought that official support here too. Guess better to talk about problems, bugs in public - then other people can read it and dont ask questions again by the private support .
mrz
Wed Mar 13, 2024 12:49 pm
Solution is just like for any other unwanted traffic. You block it.
Or upgrade to v7 and remove all BFD config.
genPSI
Sat Mar 16, 2024 11:41 am
I blocked UDP 3784 ... for now can not see problem.
upgrade 1036 to v7 ? no thanks, better I will buy new 2116
Users browsing this forum: Amazon [Bot], Bing [Bot], gotsprings, kormenator, TeWe and 25 guests
