Hi I have hap ac lite @7.10.2 that bores me with so many NTP entrieson log, I don't understand why it needs to syncronize so often ...
Normally if NTP client doesn't have to step clock, it doesn't emit any log. And normally stepping clock only happens shortly after booting device as initial time estimate is usually off by a few minutes. The rest of time device's clock should run more or less accurately and NTP client won't step it (it may perform minor adjustments, but those don't emit log entries).
So if you see frequent NTP log lines, this means that either your network is really unstable (which makes NTP timestamps jump up and down due to highly asymmetric delay) ... or (more likely) device has very inaccurate CPU clock (which makes RTC run fast or slow) and NTP has to fix it frequently.
